10 plate to a 0 plate?
Old Feb 5, 2009 | 05:08 PM
big_dog37074's Avatar
Default 10 plate to a 0 plate?
Ok I had a 10 fuel plate in my truck. I took it out and put a 0. everything works good, but on top end it doesnt fuel like the 10 plate did, and my boost is down I was boosting around37 psi. now around 34 psi. when I look at the tail pipe around 2500 theres not much smoke like the 10 plate. Anyone have any ideas.
Old Feb 5, 2009 | 07:58 PM
94cummins12v's Avatar
i know that lip on the bottom eases on the amount of fuel rather than all out, you may be running out of RPM if your net getting all the boost
Old Feb 5, 2009 | 10:58 PM
oglejust's Avatar
didnt get it slid forward?
Old Feb 6, 2009 | 12:09 AM
xzaq103's Avatar
FormerVendor
Is the AFC at full forward? Did you mess with anything else? Maybe a stock trans slipping?
Old Feb 6, 2009 | 11:09 AM
94 12valve's Avatar
have you moded your afc? if so make sure the arm is out of the way
Old Feb 6, 2009 | 01:33 PM
I have the plate and the afc both slide all the way. the star screw all the way forward.
1,2,3 gear it does fine all the way up to 3000 rpms. 4,5 gear It doesnt pull as hard, and it itsnt fueling as much as 1,2,3 gear is. one of my friends hs the same thing done to his truck as mine, but he has a 100 plate and I have a 0 plate. 1,2,3 gear I can pull away from him. 4,5 gear he comes pulling on me. does the gover arm have to be adjusted. Iam lost here.
Old Feb 6, 2009 | 02:30 PM
ajoebob's Avatar
you might cheek your fuel psi. and change your fillter. sounds like your running out of fuel.
Flikkie2001
Jun 26, 2015 12:53 AM
SMatyac
Nov 15, 2014 07:35 PM
JustAnother_cummins_guy
Nov 10, 2014 09:44 PM
hardeercy
Nov 6, 2014 08:08 PM
12v_freak
5.9L 12V Performance
9
Oct 10, 2014 02:33 PM
