Manual Fuel Pump
Old Feb 5, 2009 | 04:58 PM
K50's Avatar
K50
Default Manual Fuel Pump
Hey guys,
My fuel filter started leaking from the drain plug on the bottom, and it eventually completely lost fuel pressure so the truck died... I tightened it back up and pumped the manual pump on top of the filter until the truck started, at which point it ran fine...I'm just wondering, once it runs, is the truck fine? Is the fuel pressure good now?
Old Feb 5, 2009 | 05:59 PM
bow2no1's Avatar
if it runs fine i would say yes.
you would notice if there was any air in the lines
Old Feb 5, 2009 | 08:33 PM
Rttoys's Avatar
It's fine. No worries. It doesn't take long for all the air to purge and with the pressures that our CP3 runs, the entire system pressureizes quickly.
Old Feb 6, 2009 | 12:08 AM
2500HeavyDuty's Avatar
Old Feb 6, 2009 | 05:59 AM
bow2no1's Avatar
i see you got rid of the power ranger l
Old Feb 6, 2009 | 08:56 AM
K50's Avatar
K50
Excellent, thanks guys!
Old Mar 4, 2009 | 04:46 PM
K50's Avatar
K50
I noticed my truck was losing its prime, needed to be cranked over just a tad longer before it started to run. I changed the fuel filter and made sure everything is nice and tight, so hopefully it stops. The last couple times before I changed the filter, I'd pop the hood, pump the fuel a couple times till it was firm, and the truck would fire right up beautifully, just like it should. I saw though somewhere else that this is a common issue with D-maxes, so I'm not too worried, but I'll see if I can't stop it from losing its prime.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
bud0994
9
Jun 8, 2015 06:15 PM
ninetyoned250
Mar 1, 2015 09:10 PM
moneypitk5
Feb 12, 2015 11:01 AM
