Vulcan Performance Visit - Vulcan Performance
***Draw Straw V and Draw Straw VHF RELEASED!***
Old Feb 4, 2009 | 04:28 AM
Fishin2Deep4U's Avatar
Default ***Draw Straw V and Draw Straw VHF RELEASED!***
Finally there is a solution for the in-tank pump guys that is simple and effective for ANY aftermarket fuel pump application.
We have developed a few kits. The first being the Draw Straw V. This kit allows for any aftermarket pump to connect to the factory module fitting and get the fuel from the well portion of the fuel bucket. Installation is very easy and should make for a clean install no matter what pump you are running. The keys to this kit is that it maintains 3/8" diameter internals and the stock dorman fitting on the top of the module. Simply put, it doesn't get any easier to install a Draw Straw.
Need more flow? Gotta have 1/2" lines but still want to pull the fuel from the bucket? No problem! The Draw Straw V High Flow or DSV HF allows for a full 1/2" system starting in that same bucket. The difference here is that the fuel is drawn through a flexible 1/2" line to a Draw Straw II fitting. This kit requires drilling of the tank. Now the factory feed port can be used for fuel return. We have the dorman fittings and adapters for both 3/8" and 1/2" lines. This will dump returned fuel back into the bucket helping stop the fuel starvation issues of the bypass style pumps.
You already have a DSII and want to utilize the in-tank pump? No problem! We have a kit for you guys as well.
Keep in mind all hoses used are bio/ veggie oil compatible and are designed to hold up for the long term. We have added pictures and pricing to the site with more to follow.
Thanks for your support of the original Vulcan Draw Straw products!
Draw Straw V
Dave
Vulcan Diesel Performance Supply
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
Baradium
Nov 21, 2014 08:20 AM
