killer dowel pin
Old Feb 4, 2009 | 01:36 AM
94cummins12v's Avatar
Default killer dowel pin
killer dowel pin issues? i pulled all the intaernals out tonight and 5 piston holy hell. anywhay im going to completly eliminate the dowel pin issue by of course removing the dowel pin completely after timing case is bolted on. good idear?
Old Feb 4, 2009 | 08:25 AM
Racer9's Avatar
Bad idea! It's there to position the case. Removing it will allow the case to move around and it will start leaking.
Heres a very simple fix, you can make the tab yourself. Ram Diesel KDP retainer
Old Feb 4, 2009 | 08:53 AM
xzaq103's Avatar
FormerVendor
They put it in for a reason. Ive also heard taking it out can jack with your timing.
Old Feb 4, 2009 | 10:13 AM
Leaving it out can cause the case to walk. Tab it and its done.
Old Feb 4, 2009 | 11:44 AM
ok ill build my own tab then. im surprised that damn thing hasnt fallen out yet with the horses im pushing, i could pull that thing out with my two fingers when i poped the timing cover off
Old Feb 4, 2009 | 12:11 PM
Youve just been lucky
Old Feb 4, 2009 | 12:41 PM
Racer9's Avatar
VERY VERY lucky!
Old Feb 4, 2009 | 05:18 PM
kazairl's Avatar
The power your making has nothing to do with it. It happens to stock engines too. However my Dad's 97 had 250k and the KDP was still snugly in its hole when we pulled it apart. But your playing russian roulette with it unfixed. It is more labor than anything.
Old Feb 5, 2009 | 01:17 AM
nothin could be more labor than an entire out of frame engine overhaul, but ill just tab it
Aug 25, 2015 07:10 PM
windage
Jul 17, 2015 12:45 PM
Weeks327
May 11, 2015 10:43 AM
359ci12v
Apr 9, 2015 08:24 AM
dieseldeal
Mar 24, 2015 12:11 AM
