Boost at idle?
Old Feb 3, 2009 | 09:52 PM
Begle1's Avatar
Default Boost at idle?
'04 6.0 liter can be running 1-3 PSI of boost at idle.
True or false?
Old Feb 3, 2009 | 09:53 PM
Negitive
Old Feb 3, 2009 | 10:12 PM
Benjamin's Avatar
Bombardier
question:
what if the vanes on the turbo were to stick and make it become super restrictive? wouldn't this make it build boost? just a thought....
Old Feb 3, 2009 | 10:14 PM
Still dont think so
Old Feb 3, 2009 | 10:17 PM
Benjamin's Avatar
Bombardier
i remember back in the day when the VGT/VVT/VTG (whichever one is it) technology got big someone was prototyping a mechanical VGT/VVT/VTG turbo for use on trucks that were wastegate controlled via boost not electronics. IIRC on a 12v using this mystery prototype turbo in drive at idle it was suppose to have 1-2 psi. in neutral nothing but under that load it would build boost.... this is stuff i read on the interweb so i don't know how true it is.....
Old Feb 3, 2009 | 10:27 PM
Begle1's Avatar
This guy has some switch under his dash that makes the turbo do the obnoxious 6.0-liter constant-scream thing, so I assume that works by shrinking the VVT down really far. (They are VVT's, right?)
Somebody said it was building 3 PSI boost at idle; I said bullshit. The scream has more to do with turbine speed than boost, and there's just not enough energy at idle to build boost at idle, regardless of restriction.
But then I was thinking about it, and it doesn't really sound too far fetched. If the vanes were all the way closed, and lets say the air conditioner was on, and maybe if it was cold or the EGR was on, I might believe that it could build 3 PSI of boost.
Then I asked him, and his programmer is relaying a 1-2 PSI boost signal at idle. Which may just be inaccuracy in the OEM sender, I don't know.
So I figured I'd ask the experts to hopefully verify my honor. And somehow I figured I'd ask you guys too.
Old Feb 3, 2009 | 10:52 PM
Big Angry Hillbilly's Avatar
With the engine at 1200rpm on a fast idle switch, and the EGR valve closed as per PCM calibration to help avoid coking, some boost may be present at idle.
I did a remote start on an 06 today, and when it ramps up to the 1200 fast idle on the pto sense, the turbo does whistle pretty good.
Old Feb 5, 2009 | 02:02 AM
strokedout07's Avatar
my veins on my turbo got stuck and didnt change anything at an idle but i was hitting like 45psi on the boost gauge
but when the selinoid that controls the viens was fixed ford said it was running about 2psi at an idle but it didnt show on my gauge
Last edited by strokedout07; Feb 5, 2009 at 02:02 AM. Reason: Automerged Doublepost
ash23k
Dec 30, 2014 08:31 PM
Crews8r
Dec 21, 2014 07:35 AM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
99stackedpowerstroke
Oct 8, 2014 07:06 PM
