fuel leak
Old Feb 2, 2009 | 06:10 AM
alanbickley's Avatar
Default fuel leak
has any one had a problem with a fuel leak near the injector pump, i already replaced all the lines that go back to the tank. on the passenger side of the injector pump there is a steel line that connects to a rubber line, i changed that rubber line because i thought i saw the leak there. no i suspect that the steel line is leaking, suggestions?
Old Feb 2, 2009 | 07:16 AM
wildbill's Avatar
Possible that the banjo bolt gasket is leaking. Try cleaning the suspected area with some brake parts cleaner and see if it gets wet again.
Old Feb 2, 2009 | 05:41 PM
no it is dripping very steady, i suppose that it could be running down the line and hitting the hose clamp
Old Mar 30, 2009 | 10:47 AM
ford cummins's Avatar
I have a 98 12 valve and I recently found a fuel leak by the fuel filter/block. I believe its on the return line to the tank, it has not effected performance or starting. If anyone has experienced this same issue help me out.
Dale9411
Dec 4, 2022 06:51 PM
Dbleo351
Nov 20, 2016 09:34 AM
moneypitk5
Feb 12, 2015 11:01 AM
4x4kingx889
Jan 25, 2015 02:02 PM
Dec 5, 2014 08:30 AM
