timing 12v
Old Feb 1, 2009 | 03:16 PM
HAYMAFIA's Avatar
Default timing 12v
where can i buy a timing kit for 12 valve or how do u usually do it
Old Feb 1, 2009 | 05:35 PM
wildbill's Avatar
What are we wanting to fix.
Old Feb 1, 2009 | 09:59 PM
94 12valve's Avatar
pure diesel power sells the kit and HERE is how to do it
Old Feb 2, 2009 | 01:53 PM
HAYMAFIA's Avatar
popping and white smoke from second full throttle fine after wind up told that the timing may need advanced a little
Old Feb 2, 2009 | 02:00 PM
Yes. I would check the timing. You will probably also want to pick up a barring tools (but you can turn it engine backwards using the alternator nut).
SP500, Set, Diesel Timing Gauge
BUT, before checking timing I would look at replacing the overflow valve if you havent already. Heres some reading: http://dodgeram.info/tsb/1996/14-07-96.htm
also: http://www.dieselpage.com/tip4.htm
And 1 more good one for ya: http://www.dieselpage.com/tchart.htm
Old Feb 2, 2009 | 10:20 PM
97 D-Tec's Avatar
advanced timing shouldnt make the truck blow white un less the timings advanced to somthing ridiculous. bad injectors, a blown head gasket will make it poor white
Old Feb 3, 2009 | 01:43 AM
Were talking about slipped timing - not advanced timing.
quiksilver1j
Jul 30, 2015 12:41 PM
tom88k5
Jun 16, 2015 12:57 PM
Stox5225
22
May 14, 2015 05:17 PM
cummins Pride
Dec 31, 2014 12:58 PM
SMatyac
Nov 15, 2014 07:35 PM
