Injector connector tubes
Old Feb 1, 2009 | 02:26 PM
JSPulliam21's Avatar
Default Injector connector tubes
I understand I will need new connector tubes when I put new injectors in because of my engine serial number. Should I just find a set o stock ones from a later model, or go with the .093 connector tubes? They are both the same price. Is there a benefit to the .093's? Are there any negatives? I am thinking 150 injectors. F1, DDP, Coaltrain, Scheid, Dragon Fly's, FireBall, I don't know.
Old Feb 1, 2009 | 06:17 PM
wildbill's Avatar
.093's are a little bigger than stock??
Old Feb 1, 2009 | 08:00 PM
They are bigger than stock
Old Feb 1, 2009 | 09:28 PM
Uncle Bubba's Avatar
The engine serial number isn't the determining factor on if you have the disposable tubes or not. On the tubes themselves you will see a number stamped, I believe on a tag if I remember right. It depends on this number if you will need new ones or have the reusable ones. Sorry I don't remember which numbers are which at the moment.
The bigger lines seemed to have caused a lot of idle problems in the past, but I don't personally know anything about em other then whats been posted through the years.
