Heater Problems
Old Jan 30, 2009 | 07:18 PM
tyrel_44's Avatar
Default Heater Problems
My heater isn't working worth crap... The water temp can be 160-180, and the air is luk warm... It useto cook me out of the cab, and now i can't even get it to defrost the window.. and i'm not seeing outside temps below freezing that much, but it's still freakin cold! I think i've got a vacume leak somewhere.. because my 4x4 takes forever to kick in, and the vent selector (defrost, floor, ect..) only works if i turn my fan down.. so Is there a vacume line that controles the heat, or is it most likely my heater care plugged? Thanks!
Old Jan 30, 2009 | 07:57 PM
98_12Vcummer's Avatar
Default Dido...somewhat
yea...my heat is luke warm at best too, and its normally below freezing around here in the winter....all my air goes where i tell it to though and my 4wd works....the light doesnt come on inside the inst. cluster area, but they lock up just fine...im thinkin my heater core might be blocked...but i'm also curious if theres a special trick or something im not catching before i get the hose out to blast the core out.
Old Jan 30, 2009 | 11:01 PM
tyrel_44's Avatar
that's exactly what i was wondering.. surely we're not the only 2 people with this problem..
Old Jan 31, 2009 | 01:42 AM
jnicewan's Avatar
when you turn your temp **** full hot to full cold listen for a thump noise and that will tell you if the door fully opening and closing. but i bet its you core. some have had good results back flushing cores and some have not. it may depend on whats built up in it and how much. i flushed mine with having the same problem as yours and i got good results from it.
Old Jan 31, 2009 | 01:52 AM
wrench123's Avatar
Yea, I think I would clean the core first-done carefully it can't hurt much.
Old Jan 31, 2009 | 01:56 AM
farm boy's Avatar
yea it may be time to flush the system. that will help alot it did on my 95.
Old Jan 31, 2009 | 09:34 AM
thanks guys...thats what i figured....im gonna wait for a day above the 32 mark and break the hose out on this pig!
Old Feb 1, 2009 | 01:49 PM
tyrel_44's Avatar
and what if the door dosn't open or close all the way? is it a vacume problem? and how hard is this to fix? thanks!
kelchy82
6.2L & 6.5L Performance
10
Nov 27, 2016 04:32 PM
ramrunner01
Feb 25, 2015 11:14 PM
Mike H
Jan 25, 2015 10:08 AM
bikernut
Audio Equipment/Electrical
Dec 18, 2014 03:30 AM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
