high idle
Old Jan 30, 2009 | 06:19 AM
alanbickley's Avatar
Default high idle
is the 12v supposed to have a high idle when it is cold?
Old Jan 30, 2009 | 08:04 AM
tyrel_44's Avatar
not from the factory
Old Jan 30, 2009 | 11:45 AM
big_dog37074's Avatar
Unless you make something for it to be at a high idle no. 89 to 98 12v are not controlled by computer so there is no way for it to have a high idle.
Old Jan 30, 2009 | 05:00 PM
is there a kit for a high idle?
Old Jan 30, 2009 | 07:56 PM
2500HeavyDuty's Avatar
you can use a stick
Old Jan 30, 2009 | 08:58 PM
You can use a cable (throttle or PTO) to mechanically force it into high idle. Something like this: http://www.awdirect.com/pto-cable-10-r04d45x10/pto/ But youll have to work out the mechanical details.
Some guys have even used solenoids off of carbs, but most dont have enough holding poswer.
Old Jan 31, 2009 | 08:44 AM
Originally Posted by 2500HeavyDuty
you can use a stick
thats what i have been doing i have 2 x 4 under my seat i wedge in there
Old Jan 31, 2009 | 08:57 AM
CumminsTurbo22's Avatar
a heavy brick!
Old Jan 31, 2009 | 09:04 AM
oglejust's Avatar
i carry a sledgehammer that i wedge between the pedal and the steering wheel, if u have power seats (which i dont) u can just get a board and adjust ur rpm according to the seat
Old Jan 31, 2009 | 11:17 PM
farm boy's Avatar
you can adjust your idle by the nut on the back of the injection pump. it is a 10mm wrench. it is right were the linkage connects to the back of the pump. this will help you solve your problem. 700 to 850 is were it should be set.
