4wd problems
Old Jan 27, 2009 | 09:04 PM
woolyhorn's Avatar
Default 4wd problems
I got a 97 dodge, I cannot get the 4wd to lock in for some reason. The manual tranny will shift fine, into low and high, the light comes on, but when I hit the throttle it blinks on and off. Have any of you had similar situations?
Old Jan 27, 2009 | 09:37 PM
Red_Rattler's Avatar
High Tech Redneck
My 97 gasser would cut in and out like that. Turned out to be some vacuum lines that go to the CAD on the front axle... Check it out
Old Jan 27, 2009 | 10:10 PM
tyrel_44's Avatar
I've had about the same thing happen to me.. It was a vacume line had a hole in it..
Old Jan 28, 2009 | 11:53 AM
big_dog37074's Avatar
More than likey it is vacuam. run you a straight vacuam line to your acuator it will be the left one. it that works replace the hoses. this is the way I have mine hooked up right now. dont have time and to wet to work on it.
Old Jan 29, 2009 | 01:43 PM
cumminsman95's Avatar
Yea its definatly sounds like the vacume lines! I had the same problem.
Old Jan 29, 2009 | 06:08 PM
farm boy's Avatar
Im having the same problem right now with my four wheel drive. I will check that out to.
Old Jan 29, 2009 | 10:01 PM
94cummins12v's Avatar
it has to do with a vaccum leak. i bought a pac break vaccum switch and hard lined it into my actuator so i can control my 4x4 actuator by togle switch
Old Jan 30, 2009 | 11:48 AM
where did you get the vaccum switch at. I would like to put mine on a toggle switch
Old Jan 30, 2009 | 06:13 PM
call advanced diesel tecknology(304) 864-3399 ask for doug tell him brandon sent you there about $80 after shipping
Brody Olson
Chevy/GMC Duramax 06-07 LBZ
Sep 12, 2015 11:01 PM
2gCummins
Jul 22, 2015 11:34 PM
mw1095mw
Jan 4, 2015 11:06 PM
Tucker126
Jan 2, 2015 08:09 AM
lifted07sierra
Nov 24, 2014 10:22 PM
