Turbo experts, can I keep my wastegate clamped off???
Old May 20, 2007 | 10:10 AM
Dodgezilla's Avatar
Default Turbo experts, can I keep my wastegate clamped off???
I have an HTB2 62/12 turbo on my 07 Ram. I have not been able to get more than 35 psi out of this thing no matter what combo of boxes I have on the truck. It was suggested for me to clamp off the hose to the WG and see if I get more boost. Well, I did it and I hit almost 40psi today with my Predator/Puck combo on the moderate setting. Before clamping it off I got a max of 31-32psi. Now, I made a hard pull but if I would have stayed in it longer I think the boost would have risen more but I doubt it would have gone above 45psi. I know that 40-45psi won't hurt the turbo but would there be any drawbacks to keeping the hose clamped off????
I do have a Quad boost fooler on the truck BTW....
Old May 20, 2007 | 10:41 AM
Uncle Bubba's Avatar
I'm a little out of my league here on a newer truck and aftermarket turbo so don't take this to heart. Just throwin out a thought here. I think I would be more worried about a head gasket at 40psi then I would be of hurtin the turbo. This is where you get into the new studs or fire ringed head.
Old May 20, 2007 | 12:37 PM
GmcLbz's Avatar
Site Sponsor - Upstate Diesel Performance
It might not hurt the turbo but will your head gasket take that much?
Old May 20, 2007 | 12:51 PM
Dodgezilla's Avatar
The head gasket should be fine until around 55psi or so... I was making 45psi with this turbo when it was on my 03 w/ TST/MP8 stack. 40-45psi should be no problem......
Old May 20, 2007 | 01:07 PM
GmcLbz's Avatar
Default Head Gasket
My buddys went in his 02' with around 40#s of boost. Well at least if it did go it should'nt too bad to change! I would'nt even want to get into mine!
Old May 20, 2007 | 01:30 PM
DangerousDuramax's Avatar
Yep, the DMax turbo is a to change.
Old May 20, 2007 | 01:38 PM
GmcLbz's Avatar
Default Head Gaskets
I was talking about changing the head gaskets but I dont want to get into the turbo either! It's hard enough just to find it let alone change it!
Old May 20, 2007 | 03:14 PM
Dodgezilla's Avatar
Well, I don't even want to start talking about head gaskets so just stop it!!
As I said, the Cummins is good for around 50-55psi before you need to start worrying about it.
Old May 20, 2007 | 03:41 PM
No need to get huffy. Everyone knows that the CTD is good for 50psi as well as the head gaskets are the weak link.
Old May 20, 2007 | 03:56 PM
TEXASPOWER's Avatar
i ran a stoker at 48-50 for a yer and a half with no HG probs so youll be good as u stated now a stock turbo at those levels for over a year is a different story, poped it friday
