wonderin
Old Jan 25, 2009 | 06:30 PM
Braden Augustus's Avatar
Default wonderin
I have a 07 cummins and i was watching a video on youtube of a truck idling and it had a MONSTER LOPE. I was wonderin how i could get mine to do that. the video is called monster idle thanks.
Old Jan 25, 2009 | 06:42 PM
wildbill's Avatar
Going to have quite a project going.
And be spending a few dollars
Old Jan 26, 2009 | 05:33 AM
DB Admin's Avatar
Banned
cross over tubes are drilled out is why it lopes
Old Feb 6, 2009 | 03:14 PM
Bump for help
Old Feb 6, 2009 | 08:27 PM
Whit's Avatar
Site Mascot
2nd gen
Old Feb 6, 2009 | 10:41 PM
SOUTHERN GA SMOKE's Avatar
the only real way to get a lope is get a second gen vp pump truck and either drill out the tubes, or put .093 tubes or larger on the truck, and get either a hotrod vp or monster pump, the third gen common rail systems use a high pressure rail, and are not designed to lope, if you want a lope you can throw in a bad injector, but whats the point you know... third gens should never lope, there not designed too, sorry wasnt meaning to get your hopes down man, but with a common rail all the power should be smooth...
