2 stroke oil?
Old Jan 23, 2009 | 05:31 PM
Dan.tha.Cummins.man's Avatar
Default 2 stroke oil?
what does adding 2 stroke oil do when you add it to your fuel tank? is it healthy for the engine????
Old Jan 23, 2009 | 06:09 PM
wildbill's Avatar
Lubricates the fuel system. Burn clean if you use the ashless formula.
Old Jan 23, 2009 | 06:13 PM
89silverbullet's Avatar
only run the ashless stuff. i run it in both of my cummins. love it i felt like it made my motor go through the rpms smoother. do it. i do 1oz to every gallon. some do a gallon to a oz.
Old Jan 23, 2009 | 07:09 PM
Its needs the TCW-3 stamp to be ashless.
Old Jan 24, 2009 | 03:07 AM
Fishin2Deep4U's Avatar
If it doesn't come out of the green handle it doesn't go into my fuel supply.
Dave
Old Jan 24, 2009 | 11:47 AM
BlackDodge's Avatar
I first read about the 2-stroke trick on DB. So i figured with all of the test and trials I would give it a shot myself ( 1 oz. per gallon ) and I love it. Made engine run smoother, quieter and i have noticed a little more fuel mileage. Go For It!
Old Jan 24, 2009 | 11:57 AM
01quadcab's Avatar
it works and it's cheap.
Old Jan 25, 2009 | 09:03 AM
ok ill give it a go. is there any specific brand or is any fine as long as its ashless?
Old Jan 25, 2009 | 11:04 AM
tearin_it_up_everywhere's Avatar
i use the walmart brand it is cheap and it works it is tcw-3
Old Jan 25, 2009 | 12:42 PM
01quadcab's Avatar
yeah I use the walmart stuff too. was going to try a oil supply place and see if they had it in 5's any cheaper just to try and save a few bucks.
