1995 5.9 engine keep running after ingnition stop
Old Jan 23, 2009 | 04:01 AM
AlaskaPalmer's Avatar
Default 1995 5.9 engine keep running after ingnition stop
My rear diesel w/185K keeps idling strong after key turned to "off." Camerota in Bow, NH wants to sell me a $3100.00 P7100 Injector Pump. I've read solenoid, pump, etc. I now turn off by lifting back bed, then pushing linkage rod back into solenoid. Help!
Read about Ram problems w/blue wire to battery, etc.
Starts fine, think I smell a little diesel, but not sure.
Old Jan 23, 2009 | 04:12 AM
wildbill's Avatar
solenoid is weak or went out all together??
Old Jan 23, 2009 | 05:35 AM
gunman41mag's Avatar
Moderator
WELCOME TO DIESEL BOMBERS
Old Jan 23, 2009 | 08:28 AM
Welcome.
Dont buy an injection pump (thats pretty pricy BTW).
The problem likely is the shutoff solenoid is sticking or the starter contacts sticking. Have you ever replaced the solenoid? If you dont fix this soon you will burn up the starter. Both the blue fusible link and the relay will cause the truck to turn over but not start - so they are not causing your problem.
This is a good source for parts - while you are ordering, also get the starter rebuild kit, solenoid saver diode (Solenoid Saver Diode), starter relay kit (relay), as well as 2 sets of the replacement fuel line. You are paying shipping so you may as well get your moneys worth.
burndiesel
10
Feb 7, 2023 01:15 AM
mesjr
May 18, 2015 05:16 PM
moneypitk5
Feb 12, 2015 11:01 AM
firefighteremt
Feb 2, 2015 01:59 PM
DSM1988
Jan 25, 2015 07:23 PM
