Time for a Turbo
Old Jan 22, 2009 | 10:23 PM
Dodgehunter84's Avatar
Default Time for a Turbo
It is time for me to buy a different turbo. Thought I would ask on here and see what some of you guys and gals might suggest. I want to do twins but don't have the funds right now to go that way but, would like to get a turbo that i could use in a twin setup later. Its a daily driver and I do some towing with it also. Any suggestions would be great!
Old Jan 22, 2009 | 10:30 PM
Phat Shaft 62/14 or Super Phat Shaft 62/14
Old Jan 23, 2009 | 07:58 AM
Gixxer_750's Avatar
200hp injectors? hope you havent been running that w/ the stock turbo...200's on a 62 are gonna get hot, espically if you are towing...go w/ the 62/14 so you can go straight to twins and when you tow, turn the box off so it doesnt get too toasty
Old Jan 23, 2009 | 11:24 AM
Mr.Krabs's Avatar
He'd just have to watch the EGTs is all,I've thought about getting some 200s myself
Old Jan 23, 2009 | 11:27 AM
Gixxer_750's Avatar
150 is the absolute highest to go stock turbo...a 62 is the perfect match for 150's
Old Jan 23, 2009 | 11:47 AM
TheNatural31's Avatar
Look into the Super B charger......57/65/14 and when you get the funds go with the BD compound kit! Either way....head towards a 62/14 if you are going to go ahead with the compounds and are doing any bit of towing!
Old Jan 23, 2009 | 11:27 PM
01quadcab's Avatar
go with a s300 based turbo like what I am running as there is a truck the shop did using my same turbo as the top and it makes an easy 530hp and very towable and clean.
Old Jan 24, 2009 | 03:16 AM
Fishin2Deep4U's Avatar
What kind of twins do you want to run?
If it's a smaller/ fast spooling set I would go 62/65-14 over S400.
Little bigger power 62/71-14 over S400 or S480.
The 12cm housing would be a bit faster spooling, but would not be the best choice in compounds.
Dave
Old Jan 24, 2009 | 09:38 PM
I've benn thinking about a s300 in a 62/71-14 config. I've heard the s300 is a very reliable turbo. With the stock turbo I just watch the egt guage and when it hits 1300 I let out.
Old Jan 25, 2009 | 12:26 AM
01quadcab's Avatar
they are good turbos read up on them before I got mine.
