Edge Products, Dodge Ball Bearing Turbocharger
Old Jan 22, 2009 | 09:15 PM
puddlepirate's Avatar
Default Edge Products, Dodge Ball Bearing Turbocharger
Edge Products, Dodge Ball Bearing Turbocharger kit
Anyone on here have any knowledge about one of these? For the price it seem like a smokin deal. The tech service guy says that it will bolt on the my 89, but some exhaust/intake fab will be needed. It's looking like this or the H1 60mm upgrade. Right now I've got 279,000 on the orginal H1C, and have upgrade to a banks power pack waste gated turbine housing (14cm I think). The current set up works good, and I have no doubt the H1 60mm upgrade will only make it better. I'm thinking with that may miles I might want to go with the sale priced aftermarket, and have the brand new hardware. What can ya'll tell me?
Old Jan 23, 2009 | 12:50 AM
SPEAKSUP's Avatar
I am no Help to you I didn't even know Edge was making Turbos Even though says built by Turbonetics. So it's really a Turbonetics with a Edge polished compressor housing.
I will say that alot of people love the Turbonetics BB Turbos Alot of Tractor Pullers run them.
Old Jan 24, 2009 | 01:43 AM
higherpoweredh2o's Avatar
If its truly turbonetics you cant beat them. Pricey but awesome. I use them on gasoline drag cars exclusively no one else can hold a candle next to them in the gas world.
Old Jan 24, 2009 | 04:31 AM
Jazz's Avatar
Doesn't tell much about the turbo but, for $649.00 seems like a deal.
Old Jan 25, 2009 | 11:18 AM
RSWORDS's Avatar
Justin, get us some specs...
Old Jan 26, 2009 | 03:22 PM
Default Well it's all over but the cryin now
Here's the rest of the info I got
58mm compressor wheel (how much can 2 mm make vs. the 60)
14cm turbine housing, I forgot to get the turbine size
I can't use the waste gated housing Ive got but oh well I'll take the hit to have BB
The tech guy tells me that with the right pump mods, and injectors 40 psi is a good bet. I don't want much over 35 so I should be in good shape. Anyone got a 4 inch intake hose they want to part ways with? Once I get the thing bolted up I guess I'll find out if it was money well spent or not.
Old Feb 3, 2009 | 10:49 PM
JDGnut's Avatar
Guys, I bought one from the site listed above.. UPS dropped it off yesterday.. it might be a while before I get it installed.. I forgot that it didn't have a wastegate.. so I'll have to do some work to get in install... or install it.. and just take it easy.. (not worried about the turbo... )
I tried to measure the exhaust wheel without taking the housing off.. it looked like it was in the 69mm range...
but for that price... just the downpipe is in the 130-150 range... (yea.. it won't fit on a 1st genner..) and it as a bigger flang than an hx40..
I've been trying to read some other posts about this turbo.. only place I have found anything was the TDR.. and I'm no longer a member, so I couldn't get too much info...
I know turbonetics has a 2nd upgrade, but I don't think its on the same center section.. (the info says it comes with an adapter plate.) I was thinking of calling them, and asking about upgrades.. or more info about the turbo...
Its Bling Bling that's for sure...
Old Feb 3, 2009 | 11:06 PM
Only thing I know is that Edge has discontinued these
Old Feb 4, 2009 | 05:17 AM
Jazz's Avatar
Any idea why Luke
Old Feb 4, 2009 | 10:03 AM
JDGnut's Avatar
I know that mine was built 3/07.. and the box said 13 of 50.. So its been sitting for almost 2 years.. If I was going to guess it was mainly because of price.. its listed at $1800.. most advertise for 1300-1400.. price because of its size.. for that price you can buy a nice sized turbo... 62/64/66.. as compared to a 58... I'm sure the exhaust wheel is bigger than stock.. and it should flow better than a 35 or H1... but a ball bearing turbo for 650.. you won't find anything close.. (I see now they have it listed for 695 with free shipping.)
Bryan
The down site could be that it was built to Edge's specs not Turbonetics... Actually it was built to Diesel Dynamic Specs.. (which I will take over Edge.. knowing who is.. was working for DD)
I would be interested to know what is different from the Edge's turbo vs Turbonetics T58 Stage 1...
Bryan
