What to Stack with the Quad Adren
Old Jan 20, 2009 | 10:20 PM
oklahoma_6speed's Avatar
Default What to Stack with the Quad Adren
was wondering what you quad guys are stacking with the quad... sence the timming is taken care of.. what box would work for fuel....or can ya even stack like that on a vp44.. how would i plug it .. would i tap the the vp.. like the quad.. or what....
Old Jan 20, 2009 | 10:28 PM
biged681985's Avatar
smarty
Old Jan 20, 2009 | 10:48 PM
thats what i wasa thinking ed....... but . what other ops are out there
Old Jan 20, 2009 | 11:18 PM
Theres really no need to stack anything with the Adrenaline. If you run the HOT HOT Adrenaline tunes with large injectors it by its self will run the VP dry no matter how much fuel your lift pump can handle. If your wanting more power then add some larger injectors.
Old Jan 21, 2009 | 05:41 AM
Jazz's Avatar
I agree with Luke. I run the Adrenaline with big sticks and on the comp tune I think I'm about maxed out on fuel. You could stack the smarty, but if you custom tune the adrenaline you can get the same low end as the smarty
Old Jan 21, 2009 | 08:55 PM
Gixxer_750's Avatar
agreed...there is no need to spend another $600+ for something you already got...smarty is about the only thing worth stacking w/ something like the adr. or edge but you really dont need it...cranking up that adr
Old Jan 21, 2009 | 10:13 PM
Cumminsdieselboy's Avatar
my dad has a smarty and adr stack. we prolly have to wrong tune in but we have the one that gives it no timing from the adrenaline. we have our smarty on #9 which is catcher with timing. so the smarty is handling the timing and fueling and the adr is adding more fuel. we are in the process of figuring out our injector problems so we dont have a valid HP explanation if it helped or not.
it runs fine with the stack, even tho we went from 220hp injectors (supposedly) to stock injectors
firstgenpr
Basement Enterprises
May 26, 2015 01:08 PM
torino73
Apr 14, 2015 11:15 PM
hollywoodbusa
Wanted To Buy (WTB) - Used
Feb 22, 2015 08:05 PM
ramrunner01
Jan 19, 2015 05:01 PM
CumminsCrazed
Oct 27, 2014 09:02 PM
