dual bypass remote oil filtration system duramax
Old Jan 20, 2009 | 12:58 AM
2500HeavyDuty's Avatar
Default dual bypass remote oil filtration system duramax
300 shipped. opened up just to look at. everything is accounted for.
Attached Thumbnails dual bypass remote oil filtration system duramax-100_2154.jpg   dual bypass remote oil filtration system duramax-100_2155.jpg
Old Jan 20, 2009 | 02:14 PM
Heath's Avatar
Authorized Amsoil Dealer
Having a cleaning sale?
Old Jan 20, 2009 | 03:35 PM
Getting spring cleaning out of the way. Hey heath don't they sell a bracket now to make the install of the filters just a simple bolt on now?
Old Jan 20, 2009 | 04:54 PM
Heath's Avatar
Not that I'm aware of, just the 90 degree bracket that comes with it. Not sure if that's a new piece or not. I've not seen a dual remote in quite a while. Is this an extra one or you just decided not to use it?
Old Jan 20, 2009 | 11:44 PM
must be some other guy, i heard about some guy that makes a bracket to make it a simple bolt on tot he frame on mcrats site.
Old Jan 21, 2009 | 12:59 AM
94cummins12v's Avatar
is it the one that screws in to any 1/8" npt port, posibly mount on a cummins
Old Jan 21, 2009 | 01:05 AM
it has a filter adapter that goes right where the oem would go and has a supply and return line that goes to the dual bypass system. you can get ahold of the cummins fiilter adapter and you should be able to make it work. you might need some different fittings though.
Old Jan 21, 2009 | 01:14 AM
well what i would like to do is leave my original cummins filter in its spot ant put a suply line from the twin turbo oil port to some sort of an additive filtering system then dump the oil back into the oil pan
Old Jan 21, 2009 | 01:31 AM
you can do that
Old Jan 21, 2009 | 12:54 PM
Diesel-N-Dust's Avatar
Hmmm, I may be interested.
