Boost pressure
Old Jan 16, 2009 | 04:11 AM
97cummins's Avatar
Default Boost pressure
How come when i stand on the go pedal the boost pressure guage only goes up to 36 psi?I have a 60# guage.
Old Jan 16, 2009 | 08:13 AM
tyrel_44's Avatar
From what I understand that's all you want to put through your stock turbo. but if you want more your sig don't say your wastgate is blocked off. It comes off of the back of the afc housing with a rubber hose and then goes to a steel line to the turbo. you can get a small hose clamp and pinch the rubber hose off and it will completely disable your wasegate. But they make a proportioning valve you can buy for it to.. I have the wastegate disabled and a 100 plate and regularly see 40# boost. But everyone says it's not good on the turbo
Old Jan 16, 2009 | 02:08 PM
ajoebob's Avatar
i have mine set at 40psi. but it starts making hot air.
Old Jan 16, 2009 | 02:16 PM
DBogo's Avatar
37 psi is where it passes the volumetric efficiency of the HX35
Old Jan 16, 2009 | 09:36 PM
TXHC's Avatar
More Boost = More Power & More Heat.
Each turbo has an efficiency range specific to that model turbo, and going beyond it's range will result in turbocharger failure due to overspinning, and piston-melting exhaust gas temperatures since you're now pumping hotter air in, and clogging up the exhaust manifold with too much pressure that the turbine side of the turbocharger can't expell.
36psi is a stout amount of boost for a stock HX35 Turbocharger, and right at the limit of it's power band. With the mods in your signature, the HX35 is still a useable turbo. If you want more power, it's time to upgrade the turbo, injectors, delivery valves, fuel system, and valve springs.
Old Jan 16, 2009 | 11:30 PM
9712valve's Avatar
my dad was able to see 40lbs with his stock hx35, 10 plate, 3000rpm governor springs and his wastegate is still functioning, on his 95 5spd.
Old Jan 17, 2009 | 12:01 AM
oglejust's Avatar
w/ the wastegate hooked up, 4k gsk, 4in exhaust, cold air intake, no plate and gutted afc i was hitting 31psi now w/ the same setup except w/ the afc arm in and the wastegate plugged i can hit 45lb if i want but i dont.
Old Jan 17, 2009 | 12:47 AM
94cummins12v's Avatar
ya yu could do so much better tuning the afc than gutting it, i was hitting 45+ with a stock WH1C (pre-hx35) now with this hx35/40 hybrid non gated 16cm housing i see 55+ at times
Old Jan 18, 2009 | 12:23 AM
97cummins's Avatar
Thanks for all the tips guys.I do plan on upgrading my turbo,injectors later.
robbyS
Apr 16, 2015 02:22 PM
dango
Jan 22, 2015 04:23 PM
Tsgbk9
Dec 23, 2014 11:54 AM
cameronlee51
Oct 28, 2014 12:33 AM
GreenDieselF
Oct 20, 2014 02:05 PM
