Engine lopes after load
Old Jan 16, 2009 | 12:32 AM
haulitrite's Avatar
Default Engine lopes after load
Now almost everytime I drive the truck it seems to get worse and worse. I pulled out in front of a car today on accident and had to give her the beans....... After I reached about 35 mph I let of the pedal and the engine started to lope. It went from 500 rpm to 750 for about 10 seconds then stoped.
It will do it almost everytime.
Here is what I have done so far. Droped the tank and cleaned the pre-filter on the sending unit. Removed the fuel heater bowl and cleaned that pre-filter as well. Install a new fuel filter.
The throttle cable and linkage was replace already.
I know I have good fuel because my ISX is running fine on it.
Tomorrow I will : check vacuume on the fuel line before the lift pump. If all is good there
I don't know what else to do
Old Jan 16, 2009 | 01:01 AM
94cummins12v's Avatar
what tranny
Old Jan 16, 2009 | 11:52 AM
haulitrite's Avatar
auto trans
Old Jan 16, 2009 | 01:34 PM
ajoebob's Avatar
is it jurking when it happens?
your trans could be going out
Old Jan 16, 2009 | 05:49 PM
haulitrite's Avatar
no it doesn't jerk. I cant feel any thing
Old Jan 17, 2009 | 12:39 AM
jnicewan's Avatar
maybe fuel pump getting weak, when under load you might be getting pretty low on fuel pressure then air cavitates a little bit and lopes untill its pushed through. i had an old ford idi that did this exact thing from a bad fuel pump.
Old Feb 8, 2009 | 02:54 PM
haulitrite's Avatar
thanks
Old Feb 8, 2009 | 06:08 PM
I would look at changing the overflow valve first - get it from Cummins and make sure its a Basche one.
If that doesnt help, check fuel pressure.
burndiesel
10
Feb 7, 2023 01:15 AM
klein444
Jun 20, 2015 11:48 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
hunt4beer
Nov 15, 2014 09:06 AM
Oct 30, 2014 08:10 AM
