trans issue
Old Jan 15, 2009 | 08:45 PM
tomc983's Avatar
Default trans issue
i have a 03 chevy dmax and today for the first time me and a friend were driving down the road and he said mash it so he could here how it sounded with the exhaust. i put the peddle to the floor and the rpms jumped to 3500 downshifted then didnt shift again till i lifted. any ideas why it would not shift when its suposed to i bought it used with 72000 on it. is the trans slippin that bad? or somethin else
Old Jan 15, 2009 | 10:18 PM
uwyo_dmax's Avatar
Well if I understand what happened right i would first start with the fuel filter. I dont see a programmer of any kind in your sig so i would doubt its slipping.
Justin
Old Jan 15, 2009 | 10:24 PM
2500HeavyDuty's Avatar
no codes?
Old Jan 16, 2009 | 10:23 AM
tomc983's Avatar
no codes so far and no programers in the truck is stock except for the exhaust
Old Jan 16, 2009 | 11:32 AM
uwyo_dmax's Avatar
Then i would try changing your fuel filter. before i changed mine a while back it would wrap up to 3300 in 4th and not shift until i let out. Trans tables are based of throttle position, speed, and rpm so if your not meeting the speed for that throttle position its not going to shift.
Old Jan 16, 2009 | 11:35 AM
03maxpower's Avatar
yes change your fuel filter mine did this it was like i only had half trottle changed the filter was like new again
Old Jan 16, 2009 | 02:48 PM
tomc983's Avatar
ok thanks ill do that this weekend and see what happens
Old Jan 16, 2009 | 06:08 PM
dozerboy's Avatar
Have you changed the trans filter, should do it every 10k-15k?
Old Jan 16, 2009 | 06:34 PM
tomc983's Avatar
just got the truck about 6 monts ago wanted to get the trans servied but havent had the time
Old Jan 16, 2009 | 07:53 PM
trans filter takes maybe 2 minutes to change, just finding a cheap trans filter is hard
