how to make power,,,cheap
Old Jan 15, 2009 | 06:44 PM
soupdog06's Avatar
Default how to make power,,,cheap
taken from a thread on another forum,,,but what can I do to my cummins to make power,,,without spendin a ton of money,,,
Old Jan 15, 2009 | 07:28 PM
hereismylife's Avatar
The search button is your friend.
Search this..
1. fuel plate
2. afc
3. timing
4. injectors
5. propane
5. bhaf
6. boost elbow
Old Jan 15, 2009 | 08:21 PM
Beets's Avatar
i am building good power cheap but alot of the stuff has been done half ***. So just watch how you do it. i have no fuel plate, star screw all the way, afc coustom tweaked(not sure a buddy did it for me), timing , intake and exhaust. mine is cranked up cheap but not sure how reilable it is so i have to watch it big time.
just a lil word for the wise watch ho much you cut corners... also a plugged waste gate
Old Jan 16, 2009 | 12:13 PM
DBogo's Avatar
you should have no reliability problems with that except with the plate in that you shoudl definatly run a plate, so the rack dont stick a zero plate will give you the same effect as no plate, did you dyno that at 425/1050
Old Jan 16, 2009 | 12:17 PM
03maxpower's Avatar
yes i agree and dont buy a plate grind the factory plate down so you can slide it more thats all a 0 plate is thats a $0 upgrade
Old Jan 16, 2009 | 12:24 PM
DB Admin's Avatar
Banned
https://www.dieselbombers.com/5-9l-1...2-valve-2.html
Old Jan 16, 2009 | 12:30 PM
toy4xchris's Avatar
for injectors you can always get ahold of a new year 12v man trans 215 injectors those help out.- can be found used pretty cheap I paid about $150 for all 6.
3k gsk ( avoid the make your own shim idea its easier to just get the right part from the begining)- about $125
grind fuel plate-Free
boost elbow- around $20 I believe
some people say bhaf but in reality been told it is cheaper to buy a decent reuseable filter.(either one works though)- I think I paid about $60 for my bhaf
adjusting the timing helps alot.-Free
tweek with the afc.-Free
hope this is some help
Old Jan 16, 2009 | 01:57 PM
DBogo's Avatar
i should have a set of 215 injectors for sale shortly shoot me a pm if you are interested
Old Jan 16, 2009 | 05:07 PM
Beets's Avatar
yea i put it on a dyno this spring before i timed it again and got new injectors
Old Jan 16, 2009 | 07:04 PM
DBogo's Avatar
you got a dyno sheet i may be wrong but those numbers seem kinda high for what you have done
