03 hard start only when it is cold
Old Jan 15, 2009 | 06:15 PM
Dragon Flow Diesel 128's Avatar
Default 03 hard start only when it is cold
I have an 03 dually that is really hard to get it running when its cold. I checked fuel psi from lift pump it 8psi while cranking. Checked the fuel filter it was good. Checked the FCA it was sticking replaced it,the truck did good for like two weeks now it is doing it again. Can anyone help me i dont know what to do! oh yeah rail pressure only builds to like 1350psi while cranking that doesnt seem right because my 05 builds up to 5350psi while cranking but i want to make sure it the cp3 before i replace it.
Old Jan 18, 2009 | 10:53 AM
wildbill's Avatar
Remove the banjo bolt on the rail pressure relief and see if it's leaking.
Old Jan 19, 2009 | 12:43 PM
Checked the relief it was dry, tightened the crossover tube hold down nuts havent had any trouble out of it since.
Old Jan 19, 2009 | 02:39 PM
lilfroger's Avatar
How cold is 'real cold'?
Fuel gelling?
Old Jul 9, 2009 | 11:31 AM
veggyoilkid's Avatar
where can these be found....between fuel rail and injectors?
Old Jul 20, 2009 | 08:20 PM
Default thanks..........Dragon Flow Diesel (:
I read your problem several weeks ago, and mentioned the injector connector tubes to my mechanic. What do you know...it has made a big difference...
I owe you and diesel bombers for this one
I also had a connection problem on the plug for the FCA...Intermitent fuel pressure from poor electrical connection..
thanks again Keep that big cummins roll'in baby !!!
94turbostroker
Feb 26, 2016 07:51 PM
Dcbb93
Nov 30, 2015 10:18 AM
Blanton
Apr 15, 2015 06:29 PM
dfish001
Mar 30, 2015 03:07 PM
custom7.3
Nov 23, 2014 10:44 PM
