12 valve intermittent power & throttle response loss
Old Jan 14, 2009 | 10:13 AM
haulitrite's Avatar
Default 12 valve intermittent power & throttle response loss
The truck will drive fine until I get in under load ie. Pulling skidloader. After about 5 min of driving the motor will stay in one RMP range and sound like a jake brake is on. If I let of the pedal it wont idle down for about 3-5 seconds. When i does finally idle down sometimes it will die.
One time when it did this I let off the pedal and put the trans in neutral......Big mistake......The engine ran to the red line out of control until I shut the key off.
I don't know what it is, Any ideas?
Old Jan 14, 2009 | 10:22 AM
Diesel Dave 2's Avatar
Oh boy.....I sure hope you don't have the same problem I did.I had the same problem as you said.Does this problem only happen on the highway but yet it runs perfect in town?I heard statments that the 94 and 95 p-pumps where being replaced under warrenty when they first came out...
Old Jan 14, 2009 | 10:23 AM
Sounds like throttle cable or some pump issue.
Is it a std or auto?
There was a recall on the throttle cable - take your vin to a dealer and see if its been done:
Ill post it when I can find it.
Old Jan 14, 2009 | 10:25 AM
Yes...good idea...check your throttle cable first...
Old Jan 14, 2009 | 10:46 AM
haulitrite's Avatar
I don't do alot of town driving but the only times it happens is when the truck is at or around 55 MPH or when accelerating onto the interstate.
it is a auto
I did call the dealer there is a valid recall for the throttle cable. I will have that replaced and then see where I am at.
Thank you very much.
Last edited by haulitrite; Jan 14, 2009 at 10:46 AM. Reason: Automerged Doublepost
Old Jan 14, 2009 | 11:11 AM
That was quick - no problem....
There is also this one:
http://dodgeram.info/tsb/1994/18-01-94.htm
Old Jan 14, 2009 | 11:15 AM
Here it is - print it out and take it with you:
Recall #970 - throttle cable
Old Jan 14, 2009 | 05:45 PM
haulitrite's Avatar
I called the prior owner and the throttle cable was replaced under the recall in 2002. I visually inspected it and it looks to be in good shape.
Any other ideas?
Old Jan 14, 2009 | 05:48 PM
Whit's Avatar
Site Mascot
this is a different one
slipped timing maybe
Old Jan 14, 2009 | 08:22 PM
I had the same engine dying problem at highway speed and high rpm revs...My problem was something was sticking in the IP...But first troubleshoot it to the max.Here is what I did.
Wired up the shut down switch...test
test fuel pressure.....
Take your AFC off and check that the rack is not sticking..
Here is something i forgot to ask...When the truck dies,is the pedal very hard to press when you try to restart it?
Also....when it stalls,does it start right away or do you have to wait a min or so before re-starting??
