Turbo time
Old Jan 13, 2009 | 11:18 PM
stillbad's Avatar
Default Turbo time
I need a new turbo but im not sure which i want to go with. Im looking at either an s300 from scheid diesel or i was looking at a super b single or maybe even the special but i havent heard much bout these turbos. What do you guys know bout these turbos or which would yall get?
Old Jan 13, 2009 | 11:24 PM
stkdram55's Avatar
Id go with a Phat-Shaft but both of those turbos are excellent choices
Old Jan 13, 2009 | 11:27 PM
wildbill's Avatar
Biggest question: are you planning on keeping the current configuration for a while, or is more fuel going to be added soon?? Also, turbo lag. Getting to big a turbine right off the line, is going to hurt spool up, thus EGT's are going to get high awful fast.
Old Jan 14, 2009 | 12:29 AM
Totally depends on what you use your truck for and what your HP goals are in the future.
Luke
Old Jan 15, 2009 | 06:11 AM
97 D-Tec's Avatar
with all that fuel u could easily slap a 64/71/14 or a super b special on there. there shouldnt be too much lag at all as im runing a 64 and it lights pretty quick once i added a quick spool manifold and i got wayy less fuel then you do. Either way you go, with a bigger turbo theres going to be more power at the same psi since theres going to be a bigger volume of colder air.
Old Jan 16, 2009 | 11:40 AM
stillbad's Avatar
Thanks for the help but i decided to go with the s300 from Scheid. Its supposed to be a good turbo an works well with twins if i ever decide to go big
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
sak240
Oct 1, 2015 04:07 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
