meth or NOS...
Old Jan 13, 2009 | 09:08 PM
oklahoma_6speed's Avatar
Default meth or NOS...
witch one is better...or propane.. not sure of propane....and what size of valve springs will hold it.... studs and valve springs are getting ready to go in... meth or NOS is next..
or could a person use both... like meth around town.. and NOS when he wants to ...just turn one or the other off
Last edited by oklahoma_6speed; Jan 13, 2009 at 09:08 PM. Reason: Automerged Doublepost
Old Jan 13, 2009 | 10:16 PM
wildbill's Avatar
Either one, gonna have to machine either the head or block for fire rings. Bigger turbo, gauges (boost and pyro), DD clutch. More or less a few more parts needed.
Old Jan 13, 2009 | 11:21 PM
stkdram55's Avatar
id go with water/meth, thats my opinion
Old Jan 14, 2009 | 12:18 AM
Hes currently running a SouthBend DD, Airdog 150, Adrenaline, 150 Injectors and a Phat Shaft 62/14.
To me it would depend on what your doing with your truck. If you sled pull then you can't use NOS.
Old Jan 14, 2009 | 12:45 PM
2 wheel drive.. not sure about sled pulling... dont thimk i could move it....just got the bug. and want more power..
Last edited by oklahoma_6speed; Jan 14, 2009 at 12:45 PM. Reason: Automerged Doublepost
Old Jan 14, 2009 | 01:01 PM
Blue01cummins's Avatar
nos or water would work. nos would make more power the water meth just cools egts and more timing and nos would get bigger power and you could use both if you want to.
Old Jan 14, 2009 | 01:28 PM
Diesel Dummy's Avatar
I had the same setup as you have now, i use water/meth gains about 50 rear wheel hp, with just window wash, and i have no studs. Nitrous will make alot more power but cylinder pressures will be alot higher than water/meth will and just studs might not hold it.
DD
Old Jan 16, 2009 | 09:09 PM
how did you like that setup deisel dummy...what you mean bt window wash...... not geting that....
Old Jan 16, 2009 | 09:14 PM
94cummins12v's Avatar
thats what water/meth is basically washer fluid, thats what my brother uses as well
Old Jan 16, 2009 | 09:59 PM
where do ya get it at.. is my ? if i got a set up.. where in the heck would i buy more ...surely it aint washer fluid,, the blue stuff
