Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
service 4wd
Old Jan 13, 2009 | 07:33 AM
DIRTYMAX2004's Avatar
Default service 4wd
this morning i started my truck to warm it up and when i got in after 20ish min i went out to go leave and on the message center it said "service 4wd". so i called the guy at the dealer that does all the factory work on my truck and he said to bring it in right away cuz there is something major wrong... but idk i dont think there is anything wrong... the 4wd engages and disengages just fine and it works fine...
Old Jan 13, 2009 | 07:34 AM
Johnny Cetane's Avatar
I'd guess that it's either the dash switch or the frame ground. The frame ground is cheap and easy to do yourself so I would start there. If the code comes back then take it in to have it scanned.
Old Jan 13, 2009 | 07:37 AM
where is the frame ground located again???
Old Jan 13, 2009 | 07:48 AM
I was looking for the thread I started about it.
https://www.dieselbombers.com/chevy-...-gremlins.html
The ground is located on the body mount support underneath the truck, outside of the frame, driver's side, basically just below where you put your left foot when driving.
Hey I finally found a picture too. :upup:
Last edited by Johnny Cetane; Jan 13, 2009 at 07:49 AM. Reason: Automerged Doublepost
Old Jan 13, 2009 | 07:50 AM
thanks man... its nice to have you guys that know alot bout our trucks... i know some but when it starts getting into the electronics and stuff count me out
Old May 4, 2009 | 09:57 PM
jlawles2's Avatar
Mine did the same thing when it was about 2 years old. Took it to the dealership and they removed the frame ground, scraped/ground the connection point to the frame and reinstalled it. The tech said he had seen this before. The only code it throws is a communication failure in the can system. Unless they are plugged into it while it has the message or when it throws the code, there is no way to know which can system is the issue. Mine did it twice in the past 5 years, neither time could I duplicate the message, and neither time did it affect the 4wd system.
Flikkie2001
12
Aug 29, 2015 10:03 PM
2gCummins
Jul 22, 2015 11:34 PM
woodsman27
May 23, 2015 10:16 AM
mw1095mw
Jan 4, 2015 11:06 PM
lifted07sierra
Nov 24, 2014 10:22 PM
