transmissions Promblems
Old Jan 12, 2009 | 10:14 PM
cumminskid92's Avatar
Default transmissions Promblems
I was wondering if there was anyway i could get a wiring schematic for a A518.
Old Jan 13, 2009 | 08:04 AM
BC847's Avatar
The following is for a '93 W250 with the A518. Hope it helps. (You may have to zoom in even after enlarging the images).
Cable routing and plug locations . . .
And wiring associated with the OD . . . .
(Unless I'm mistaken, once vehicle speed sensors, trans fluid temp sensors, etc are set, the PCM grounds the light-grey wire of the OD solenoid. The ignition switch applies 12vdc to the dark-blue wire).
Park/Neutral switch . . .
And transmission thermo switch . ..
Old Jan 13, 2009 | 01:28 PM
RSWORDS's Avatar
Dang David!!! You The MAN!!!
Jul 21, 2015 06:50 PM
Walker.B
Chevy/GMC Duramax 01-04 LB7
12
Feb 21, 2015 03:08 PM
Dec 30, 2014 09:10 AM
