04 1/2 boost/ turbo question
Old Jan 12, 2009 | 01:08 AM
BigGreenMonster's Avatar
Default 04 1/2 boost/ turbo question
i have an o4 1/2 w/ a smarty box i run on 5. max boost i have ever seen is 35 and that is a spike. it will settle back to 30-32 usually. my 24v buds are makeing 40-45 all day. is the cr turbo wastegated and if so how do you fool it? stock turbo btw
Old Jan 12, 2009 | 03:49 PM
MegaMan's Avatar
I'm seeing 38 with only intake, exhaust, and Quadzilla Max Mileage. The QMM has a built in boost fooler which I think basically just makes the wastegate hold out longer before it dumps.
Old Jan 12, 2009 | 04:51 PM
JTProuhet's Avatar
I have the edge juice with attitude along with intake and just straight pipe, i have seen 38-40 boost psi before, and i have the backdown turned on so if it hits 38 it starts backing it down and it has backed down as much at 45%...
Old Jan 12, 2009 | 05:23 PM
nmlakerat's Avatar
maybe having a six speed HO has something to do with it
Old Jan 12, 2009 | 05:48 PM
MegaMan's Avatar
Sorry, I may have spoken out of turn here, my truck's an 06. I think the stock 06 got a little more boost than the earlier models?
Old Jan 12, 2009 | 10:09 PM
Dragon Flow Diesel 128's Avatar
all you need to do is download the SO6 software on your smarty (Mads Electronics - Smarty - CaTCHER - Dodge Tuning - Home) and turn your wastegate off (its an option on your smarty). before i only had 32psi but with it off i get 45psi
Old Jan 15, 2009 | 05:28 PM
call me nancy but... i do not know about turning the waste gate off! i cannot believe there is not a "tuneable" setting insted of an on/off. my bud suggested using a boost elbow andthem putting a manual valve on it where you could set it say for 42 or so.
sak240
Oct 1, 2015 04:07 PM
torg73
May 11, 2015 03:08 AM
n2brk
Feb 21, 2015 09:05 AM
scottxmorris
Nov 11, 2014 03:28 PM
GreenDieselF
Oct 20, 2014 02:05 PM
