dodge help
Old Jan 12, 2009 | 12:49 AM
adub12valve's Avatar
Default dodge help
Ok when i shift my truck from neutral to reverse or drive the whole truck jolts forwards. Also it seems like if it isnt warm it will shift from 1 to 4 gear and skip 2 and 3 gear. What do you think?
Old Jan 12, 2009 | 01:46 AM
Uncle Bubba's Avatar
The truck jumpin like that is probably accompanied by a cluncking noise and this sounds like a worn U joint on the drive shaft. Just crawl under there and twist that shaft back n forth to see if there is any play in the ends.
The other, don't have a clue. I'm strictly a hand shaker tranny man myself.
Old Jan 12, 2009 | 02:33 AM
ETXBlueRam's Avatar
Some other things you might check would be your pinion nut on the rear axle, the transmission mount, as well as making sure the bellhousing bolts are tight. any or all the above will make it clunk. I'd also check the ujoints like Uncle Bubba suggested.
The shifting problem almost sounds like the converter is locking up too soon. Can you feel it shift through each gear, or does it shift one time and then lug?
JB
Old Jan 12, 2009 | 01:46 PM
ok i ordered u joints, and it just shifts from 1 to 4 and misses 2 and 3 gear and lugs. i can shut it off and re start it and sometimes it will be fine
Old Jan 12, 2009 | 01:58 PM
Hope ya did check the U joints first to make sure they are wore out. Hate to see ya just throwin money at it.
Be sure to fill in your signature also so we know what kinda truck and toys were dealin with here.
And welcome to the site.
Old Jan 12, 2009 | 03:32 PM
I had the front end re built and that is the only thing that they didnt replace.
How do I fill it in? And thank you
Old Jan 12, 2009 | 05:15 PM
Click on yer name in this post and go into user options, you'll see your signature in one of the option blocks there. Fill it in with all the details you can think of about your truck.
Back to your truck. You U joints on both front wheel hubs and both ends of the front and rear driveshafts. The driveshaft ones are generally the problem with these systems.
Old Jan 12, 2009 | 05:52 PM
lilfroger's Avatar
Not the greatest FAQ's in the world but a good start....
Diesel Bombers - FAQ: User Profile Features
May 7, 2015 02:50 PM
Dec 29, 2014 10:20 AM
Dec 12, 2014 12:30 PM
Nov 16, 2014 06:10 PM
Nov 3, 2014 08:10 AM
