Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
high egt's lately
Old Jan 11, 2009 | 08:53 PM
DIRTYMAX2004's Avatar
Default high egt's lately
idk if it is a big deal but my truck is running 800-1100 degrees criusin at 75-80 mph... it used to run 700-900 degrees i dont ever recall it goin over 1000 in the same situation... it has been very windy but i dont think it should effect it that much... and one night onmy way home from work the turbo had a hummm to it at 80 mph only... if i dropped the criuse to 75 the hummm went away... i thought maybe my egt probe was bad but it is brand new... all in all im just kinda worried... i have an edge jiuce with attitude cold air intake and 3.5" straight pipe...
Old Jan 11, 2009 | 09:05 PM
Rttoys's Avatar
Changes in programming will normally change EGT's. Is all that the same from then to now?
Old Jan 11, 2009 | 09:10 PM
yes ive had the egt probe sense i installed the edge... i always have it set in economy unless im messin around... and if i put it in stock setting it drops the egt's bout 50 degrees but it still runs up to 1000
Old Jan 11, 2009 | 09:14 PM
Rttoys's Avatar
Tires the same size as before too?
Doesn't really make since if everything is the same. The wind will add to load and add EGTs, but the cooler weather will help lower EGTs due to cooler intake air and cooler air through the rad/intercooler stack.
Old Jan 11, 2009 | 09:17 PM
ive been runnin the bigger tires for bout 2 months now... but come to think of it my air filter is quite dirty
Old Jan 11, 2009 | 09:21 PM
2500HeavyDuty's Avatar
that could be a problem, ive hit 1600* before with a clogged filter mudding with no programmer on the truck either
Old Jan 11, 2009 | 09:28 PM
Rttoys's Avatar
possible air filter.
Old Jan 11, 2009 | 09:29 PM
i dont like the k&n that i have on there right now and i dont want to reinstall my stock air box mainly cuz idk where it is ... i just want to get a different cone filter
Old Jan 11, 2009 | 09:40 PM
Rttoys's Avatar
It's been tested that the stocker filters and flows better than the aftermarket units.
Old Jan 11, 2009 | 11:19 PM
idk i seen a big increase in mileage when i put mine on
