Slip Yoke
Old Jan 11, 2009 | 06:29 AM
wyoranch's Avatar
Default Slip Yoke
Ok guys, ive got a good one for you. My slip yoke is leaking oil. I thought it was from the seal on my transfer case, but my transfer case is brand new, less than 1k miles on it. This leak is what caused me to trash my last one. Anyway, the leak is actually at the back of the yoke where the knuckle mounts to it to attach the driveshaft. Are these things just pressed together? Is there something that seals it up that is replaceable? The only oil coming out of it is from behind the weight, right in the center of the yoke, the u joint is wet with oil.
Old Jan 18, 2009 | 11:03 AM
wildbill's Avatar
Is it on the front shaft or rear shaft??
Old Jan 19, 2009 | 08:32 AM
wyoranch's Avatar
Its the rear driveshaft. It is leaking back behind the balancer ring thing, not around where the yoke goes in the xfer case like you would think. The oil is coming out right where my ujoints are. It is a very slow leak. I think there may be a small crack in the back part of the hollow part of the yoke
Old Jan 19, 2009 | 10:03 AM
wildbill's Avatar
So it's on the yoke that bolts the t-case??
Old Jan 19, 2009 | 10:18 AM
wyoranch's Avatar
No, it slips in the transfer case. It has the balancer ring on it and after that your ujoints bolt to it.
Old Jan 19, 2009 | 10:26 AM
wildbill's Avatar
Bout the only way to see if it's cracked is to have it magna-fluxed. Could also be a bad seal to.
Old Jan 19, 2009 | 10:28 AM
wyoranch's Avatar
Is there a seal in the actual slip yoke? Its not leaking at the tranny seal. Its leaking out of the slip yoke in the area where the ujoint goes on, right behind the balancer ring. I figured maybe the ring is pressed on and theres a seal in there
Old Jan 19, 2009 | 10:31 AM
wildbill's Avatar
On the slip yoke, there is a ring that threads a dirt/grease seal into place. Should be isolated from any/all oil. Pull it all apart and see what it looks like.
Old Feb 9, 2009 | 11:48 PM
wyoranch's Avatar
Update: The oil was coming from a plug that goes in the back of it. It is basically the same thing as a freeze plug. You cant buy it anywhere that i found. I guess you could just pull the slip yoke and clean the inside real good and put some rtv on there if it happens to you.
Also, if you buy a new slip yoke, go ahead and get the whole driveshaft, its only $20 more and includes BOTH ujoints
Old Feb 11, 2009 | 05:41 AM
SLVRbullet's Avatar
i`m taking my truck in on Monday to have the exact same leak repaired by the dealer,seal & everything is bone dry..yoke fluid all over it... mine was sling tranny fluid all around under there. This one is covered under my 30 day warranty though...even still dealerisn`t to happy about having to fix it.
