Gasser Diesel Swap
Old Jan 10, 2009 | 05:45 PM
twistnwire's Avatar
Default Gasser Diesel Swap
Hey,What problems should I be aware of when swapping out a 91 360 gas engine and auto transmission for a 93 5.9 diesel and auto transmission.Both trucks are Dodge 1 tons with overdrive transmissions.Any major problems? Twistn.
Old Jan 11, 2009 | 10:31 AM
RSWORDS's Avatar
hhhmmmm..... Wiring. I think the gauge clusters are the same. Core support is different for the intercooler. Engine mounts. Should not be too hard as long as you have the ability to handle this project. Just put the trucks side by side and start swapping!
And
Old Jan 11, 2009 | 12:35 PM
twistnwire's Avatar
any type of computer stuff on the 93 doner truck that has to make it to the reciving truck?
Old Jan 11, 2009 | 03:24 PM
RSWORDS's Avatar
the TPS for the tranny. And yes there is a computer. Without it your Alt wont charge (vol reg wont work) and you intrement cluster wont work. Just take everything connected to teh engine/tranny
Old Jan 11, 2009 | 05:17 PM
twistnwire's Avatar
Thanks, sounds like it is straight forward.Thanks again,Jerry
Old Jan 12, 2009 | 07:43 PM
GO OVRIT's Avatar
You can wire the alt with an external regulator. Its super easy and reliable. The 91 gasser should have the same grill as the 93 ctd, so getting the intercooler in there should be no problem. The wiring harness is different both in the engine bay and behind the dash. You also have a different message center in the gasser. There are some other differences that aren't critical. The gasser has a d60 in the rear instead of the d70. I'm not sure about the frame. I know my 90 350 gas truck has the smaller frame rails.
Old Jan 12, 2009 | 09:48 PM
RSWORDS's Avatar
Listen to this man... He is very wise in the ways of the 1st gen. He is were I have learned most my stuff.
Thanks Mike!
Old Jan 12, 2009 | 10:41 PM
txredman's Avatar
Texas Mafia
Sounds like GO OVRIT knows what to do. I put a '97 460 out of an F350 into an '89 Bronco C350 - frustrating at times but with a little alcohol it becomes a fun task chasing wires and all
Old Feb 5, 2009 | 03:20 PM
JDGnut's Avatar
Go.. Wasn't there a frame change some where in there.. I thought it was with the later 91.5+.. but can't remember... but I don't know if the frame change was just for the diesels.. or all 3/4 and up???
Bryan
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
DirtyDiesel58
Jun 7, 2015 11:50 PM
twinboys
Ford Excursion 99-05 7.3L and 6.0L
Feb 8, 2015 11:41 AM
wolfnexus
Nov 4, 2014 10:04 PM
