370 marine nozzels
Old Jan 7, 2009 | 06:50 AM
TwinStackPete379's Avatar
Default 370 marine nozzels
I am running 370 M nozzels in my truck with stock pistons. I'm not happy with them. To me they run hot. I don't care that they haze a lot but for the power I don't care for them. I know they run a different spray pattern . My question is: are there any upsides for these nozzels without marine pistons? Thanks
Old Jan 7, 2009 | 07:13 AM
gone ropin's Avatar
i ran them in my truck a while did fine but the marine pistons have a diffrent top on the pistons for the spray pattern, but i only ran the stock delivery valves in my pump so they didnt make it as hot but did good for about 296, 000 miles, i went back to 90 hp injectors and now have a fully racked pump minus the DVs, just dont need that much fuel for pulling a horse trailer, but i do need to get a bigger turbo,my buddy had the same set up as yours and he ended up roastind a cylinder, hope this helps, DR,Evil will probley have better info to answer this,
Old Jan 7, 2009 | 08:31 AM
jasonw's Avatar
No. They are junk without the matching pistons. Wrong spray pattern which leads to heat and smoke. Neither of which I like.
Old Jan 9, 2009 | 08:27 PM
Dodgehunter84's Avatar
I would get some New Era 370s, they wouldn't get as hot. less heat = more power.
Old Jan 9, 2009 | 09:00 PM
I want to get rid of them for something a little bigger. Any idea on what I should get? Thanks
Old Jan 9, 2009 | 10:43 PM
HelenaTDI's Avatar
I hear Dynomite Diesel Performance injectors are the bomb
DDP 3's (90hp) or kick it up to DDP 4's (140hp). I plan on installing some DDP 3's late spring along with other goodies. Good luck. Just my .02
Old Jan 10, 2009 | 06:44 AM
97 D-Tec's Avatar
you might not want to go bigger as u r flowing waaaay more fuel then u need to w/ the stock charger which is part of the reason for the heat. more then likely if u even went to some proper 90 hp injectors the power will be better but the heat is still going to be there since you probably have no air(stock turbos pathetic imo), the restictive exhaust elbow and from ur sig seems to be a stock exhaust. basically ur asking for the turbo or the pistons to go.
Old Jan 10, 2009 | 07:06 AM
CTD03's Avatar
Old Jan 16, 2009 | 03:08 PM
ajoebob's Avatar
i like my ddp injecters they dont smoke unless you make it and they dont get to hot it you dont get in it too much.
i'm in the same spot you are its time for a new turbo
Old Jan 19, 2009 | 10:31 PM
He has 4 inch exhaust, he just didn't put it in his sig. He is a friend of mine.
