VP44 Information
Old Jan 7, 2009 | 04:49 AM
wildbill's Avatar
Old Jan 10, 2009 | 02:17 PM
Mr.Krabs's Avatar
okay,this must be where we post stuff relating to the VP,info,and where to buy eh?
I'm down for that.
Blue chip has some info too.
VP44 DIAGNOSTIC HELP
MWFI has the CPL tag location at the bottom of the page.
Dodge VP44 Bosch Injection Pump Cummins 5.9L 24 Valve
Old Jun 23, 2009 | 11:28 AM
97cummins4x4's Avatar
i have seen the hotrod version of the vp44 does this fix the common failures?
Old Jun 23, 2009 | 12:23 PM
Uncle Bubba's Avatar
The HRVP is pretty much a dead issue. It's been proven to only be worthwhile in a very few select case where it is the only HP mod being used, other then that it takes power away from your other mods and is counter productive.
Old Jun 23, 2009 | 01:12 PM
And makes it run like crap. A couple of buddies had the hot rod pump and they didnt like it.
Old Jun 23, 2009 | 06:29 PM
k i can cross that out then so i have heard that u can p-pump the 24v is that converting it to the p7100 injection pump? and if so can sombody post somthing on that
Old Jul 9, 2009 | 10:03 PM
powerup's Avatar
HAVN,T HEARD ANY ON THE P-PUMP TO REPL. THE VP-44
Old Jul 9, 2009 | 11:40 PM
DB Admin's Avatar
Banned
there is a conversion kit to put a p7100 on a cummins 24V
Old Jul 15, 2009 | 08:42 PM
greenmachine98's Avatar
if you go to puredieselpower.com they have the VP44 to the P7100 fuel lines and my suggestion is to find a p pump at a junk yard unless you want to pay 2500 dollars for a new one
Old Jul 16, 2009 | 02:53 PM
jkidd's Avatar
Fueling limits of the HO pump is about 500HP
Fueling limits of the SO pump is about 600-650HP
remember you can put an SO on an HO and it will run and produce more power if you have injectors and box
