2.5 Ton Rockwell axles & other offroad parts 44" tires
Old Jan 4, 2009 | 04:07 PM
cummin_un_glued's Avatar
FormerVendor
Default 2.5 Ton Rockwell axles & other offroad parts 44" tires
(2) steering 2.5 ton rockwell axles, new kingpin bushing, new boots and retainers, welded diffs, both axles have the hubs flipped to 69" WMS width one axle has the diff turned 180* for a centered driveshaft for a rear steering axle, also i have (2) toyota 4cylinder IFS calipers for the pinion brakes but i do not have the brackets, you can get those on ebay for $75
i also have the driveshafts for these axles as well as (5) 20" military wheels with tires and (4) 15x10 steel wheels so someone could make the wheels to fit these axles
i also have (1) rockwell 2.5ton rear axle complete but the reduction gear has some chipped teath and a pinion bearing is bad in it, but still some good parts there
i am asking $2200 for all of the above and i would rather not seperate
i also have a set of (4) 44x18.50-15 ground hawgs 75% tread have some cracks in them but still hold air just fine asking $1100 for them
(2) high pinion dana 44 front axles from ford F150s complete one with lockhubs make offer
a pair of XJ jeep front coils, a pair of f150 front coils, 57" chevy 1-ton rear springs make offer
Old Feb 4, 2009 | 06:18 AM
wildbill's Avatar
Free bump!!
Old Feb 15, 2009 | 04:40 PM
jeepster's Avatar
If you still have the axles im interested.Where you located at and how can i get in touch with you?Thanks Mike D
