No power steering or brakes
Old Jan 3, 2009 | 11:51 PM
921stgen's Avatar
Default No power steering or brakes
My brother went to leave in his 02 lb7 crew 4x4 an hour ago and had no power sterring and the brake pedal went to the floor. Both fluids are full. I don't know much about the hydroboost system, don't know if thats the problem or if a bad power steering pump would have something to do with it. No play or noise in pump pulley. The only thing I found in a few minutes of looking in the dark and raining cats and dogs was a big 40 amp in the big block of like 1" fuses toward the engine side of the fuse panel that was labelled stud was blown. Any ideas? Thanks, Kurtis
Old Jan 4, 2009 | 12:02 AM
2500HeavyDuty's Avatar
there is a check valve that messes up on the pump sometimes.
mine has done that to me once, i had to keep the engine rpms up above 2000k rpms to even have a chance of turning.
but also a broken shaft will stop your brakes and steering to stop working.
replace the pump, theres 5 bolts iirc holding the pump on there 3 of which are hiding under the pulley. oh yah might want to replace that fuse
Old Jan 4, 2009 | 05:12 PM
Rttoys's Avatar
The PS pump controls both systems. Sometimes the pressure valve will stick, a swift jab of the brake pedal while the truck is running will make it work again.
Most of the time it's a broken shaft in the ps pump though.
Replace the fuse, it controls the + to the 7-way trailer plug. It has nothing to do with the PS though.
Old Jan 5, 2009 | 04:28 PM
921stgen's Avatar
Yes broken shaft got it replaced today.
Old Jan 6, 2009 | 12:08 AM
good to hear
Old Feb 18, 2009 | 09:24 PM
02_duramax's Avatar
awesome
ramrunner01
Jun 1, 2015 12:10 AM
scottxmorris
Nov 30, 2014 09:25 PM
GCTownes
Oct 21, 2014 10:17 PM
1MooseheadPlease
Oct 13, 2014 05:33 AM
sweetv8s10
Oct 7, 2014 09:47 PM
