Knocking and black smoke...
Old Jan 1, 2009 | 08:54 PM
WangoTango's Avatar
Default Knocking and black smoke...
I have a 2003 LB7 motor that has a knock in the #7 or 8 cylinder, and it is blowing black smoke, still runs good, but knocks. I pulled the pan on the motor there are no metal shavings whatsoever in the pan, Not sure what it is? I was told if it was an injector tip its possible but im stumped? any ideas???
Old Jan 1, 2009 | 09:11 PM
wildbill's Avatar
Sounds like an injector related issue. Done any modifications, such as a programmer or module??
Old Jan 5, 2009 | 05:53 PM
WangoTango's Avatar
Default Re:
No mods, i suppose i can pull the injectors and look them over next...
Old Jan 6, 2009 | 12:06 AM
2500HeavyDuty's Avatar
If you have a tech 2, efi live, ppe, quad stealth 2, predator tuners you can check the balance rates on the injectors
Old Jan 6, 2009 | 12:24 AM
wildbill's Avatar
Possible he blew the tip on one or more of the injector nozzles??
Old Jan 9, 2009 | 02:18 PM
GTRW3T's Avatar
the way it sounds its a injector problem. we hace alot of lb7 duramaxs come into the shop with injector problems. there warrantyed up to 200,00 miles..
Old Jan 10, 2009 | 11:26 AM
Woody35's Avatar
i would take the truck into the shop and get some new injectors
Old Feb 26, 2009 | 10:52 PM
hondarider552's Avatar
sounds like new injectors are in the near future.
Old Apr 1, 2009 | 09:29 PM
wyo_Dmax's Avatar
Gm has a warrantie of 200,000 miles or 7 years i would take it in and have it done before your warrantie runs out.
Old Apr 19, 2009 | 03:25 PM
Red_Rattler's Avatar
High Tech Redneck
If this is the motor for the 70 Chev conversion, would GM still honor the warranty on just the motor?
