hi guys-- bosch ve pump indexing accel shaft
Old Dec 31, 2008 | 04:09 AM
cfm's Avatar
cfm
Default hi guys-- bosch ve pump indexing accel shaft
hi there - can anyone help here, my refurbed ve pump came back with the top casing(where the accelerater shaft fits throug) broken..
my old pump is dissasembled,(not by me) so i need to know how to index the accel shaft in relation to governer spring/cam....
can anyone help me out here????
cfm
Old Dec 31, 2008 | 06:42 AM
RSWORDS's Avatar
Here is the write up on the 3200 spring install (if you dont have the 3200 spring you should get one befor putting the pump together anyway) you should be able to look at the pics and find your answers.
http://dens-site.net/Dodge_CTD/Gover...ing/index.html
Old Dec 31, 2008 | 06:56 AM
Whit's Avatar
Site Mascot
Welcome to the site CFM
alot of smart VE pumpers here will be able to help ya out bro........starting with RSWORDS article
Old Dec 31, 2008 | 07:17 AM
RSWORDS's Avatar
I dont know about that!
I just found ALOT more fuel in my pump! I'll have an article up soon, was easy to, had some beer, had a grinder, had my pump, and had a half *** Idea in my head! Turned out good!
Old Jan 6, 2009 | 11:49 AM
cfm's Avatar
cfm
hi guys,..
well things get complicated..
impossible to start..
i emptied a can of easy start down the turbo, it runs until, it stops--
it seems like fuel is not getting into engine..
several theories-
=== injectors blocked (6 i doubt it)
===not enough pressure to lift injector springs
===so much air in the lines the injectors wont open- but i bled 'em)
===governor spring adjustment??? - i faffed about with it makes no difference..
she cranks over fine, fuel gets to injectors ok- i undid injector banjos..
QUESTION!!!
is the pump ratio 1 to 1 with engine??
theoretically, with the gears inside, you shouldnt be able to mis phase the pump-
ex, the keyway in timing gears can only go in 1 way, you dont have to phase with motor??
wtf is going on?
can i put pressure guage into **** of pump and check pressure( should be able to)
thru center bolt.. if so what range??
any ideas....
cheers.
Old Jan 6, 2009 | 02:01 PM
RSWORDS's Avatar
hhhmmm....
Let me do some thinking on that one
Old Jan 6, 2009 | 11:16 PM
Begle1's Avatar
The injection pump drive shaft moves at camshaft speed; the keyway on the pump driveshaft is therefore capable of being installed 360 degrees off. You're supposed to use the little shaft on the side of the pump with the 5 sided washer to lock the pump to #1 TDC before it's removal.
Check to make sure the fuel shut-down solenoid is getting voltage; that's the most common crank-but-no-start cause on these trucks.
If the solenoid has voltage, and the pump isn't 360 degrees off, then it's possible that the throttle shaft is indexed wrong.
I've never had the problem, so I don't really know how it should be indexed; I'd imagine that you want it so that the internal lever the spring attaches too would have as much forward-motion as possible under full throttle without contacting the case. The farther the spring is pulled forward, the faster the pump goes. I'd think that just holding the pump at full throttle while cranking would be enough to verify a throttle shaft misadjustment, unless you were way off.
Another outside shot is that the fuel screw on the back isn't in far enough.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
