Annoying sound
Old Dec 31, 2008 | 12:31 AM
Big_Johnson's Avatar
Default Annoying sound
So it doesn't seem to be bothering anything but there is just a high pitch noise that annoys the crap outta me and it usually only happens between 20-45mph. and normally only in the higher rpms(2700-3300). i know it's not my turbo duh. but i'm not quite sure what it is. it sounds like air goin through a tight space maybe. or kinda like when you whistle with a piece of paper(if you know what i'm talkin about). but yeah any ideas about what it is?
Old Dec 31, 2008 | 12:39 AM
stkdram55's Avatar
is the door shut??
Old Dec 31, 2008 | 01:04 AM
Oilfield_Mafia's Avatar
My guess is turbo whistle.. it can be deceiving.
Old Dec 31, 2008 | 07:44 AM
Rttoys's Avatar
Sounds like a turbo whistle to me too. Check everything on the intake and exhaust that you've jacked with. On the exhause side, just look for black soot marks to find the leak.
A known problem with the LB7 is a rub through on the dr boost tube. Check the dr boost tube, down low. It makes contact with the power steering return line and wears a hole in the boost tube. You may need to remove the tube to inspect it, because it wears on the bottom side. I'll try and find a picture for you.
Old Dec 31, 2008 | 08:19 AM
Whit's Avatar
Site Mascot
I say turbo whistle too......tighten every boot
yer gonna laugh at this but I have seen it many many times...................when the fog is thick and making lotsa frost....it builds up on yer radio antenna and whistles like crazy....very high very schrill whistle....pull over and knock the frost off the antenna and it quits.....serious man its weird
Old Dec 31, 2008 | 09:06 AM
Rttoys's Avatar
You need to lay off the sauce Whit....
Old Dec 31, 2008 | 01:00 PM
lmao. yeah it's definately not frost on my antenna. but i will check all my boots. i thought i had already but i just remembered one that i missed. so i'll go check it out and see if that fixes it.
Old Dec 31, 2008 | 04:18 PM
2500HeavyDuty's Avatar
windows all the way up?
Old Jan 2, 2009 | 11:43 AM
yes the windows are all the way up.
however the passenger window was making an annoying sound the other day but it's fine now.
GT_Eleanor
Aug 24, 2015 12:11 AM
Timglow546
8
Jun 3, 2015 10:13 PM
JoeRamsey26
May 29, 2015 06:40 PM
mpmcbride42
Apr 7, 2015 08:28 PM
xj_crawler
Dec 4, 2014 09:09 PM
