47re Won't shift at wot
Old Dec 30, 2008 | 12:00 AM
hereismylife's Avatar
Default 47re Won't shift at wot
I am wondering why it will not shift at wot. If I leave off a tad it will shift perfect through all the gears.
I was searching this for awhile and came up with some questions.
I am still wondering what does the tps actually control? Why does it have to be at 1-1.2 at idle and 2.2-2.9 at wot? ( I do have a standalone ats valve body and can check what the low & high settings are).
Does the tv cable actually change the upshift? I did find out it is also a kickdown cable if I am right.
I am tring to figure out if my problem is in the standalone or the adjustments on my linkage.
thanks
Old Dec 30, 2008 | 02:54 AM
DB Admin's Avatar
Banned
sounds like your linkage adjustments
Old Dec 30, 2008 | 03:43 AM
You need to adjust your Throttle Valve Cable
Old Dec 30, 2008 | 08:39 PM
spoolinaround's Avatar
defiantly a adjustment issue, mine did that after a rebuild and it took some messing but the guy got it right
Old Dec 30, 2008 | 09:18 PM
thanks
I am going to adjust the tv cable tomorrow to see if that helps.
Old Jan 3, 2009 | 08:25 PM
browndodge12v's Avatar
where is the tv cable located mine is doin the same thing
Old Jan 4, 2009 | 01:14 PM
it is located at your on your pump where the throttle linkage is and goes down to the side of your transmission.
Old Jan 4, 2009 | 11:51 PM
jnicewan's Avatar
doubt its tv adjustment, i have been adjusting mine for awile and cannot see this causing the concern. tv mainly influences 1-2, 2-1, 2-3, 3-2 shifts with gov press. then the tp influences only 3-4, 4-3 and lock-up functions with tv & gov press. if you dont shift at wot cause of tv it would upshift late and hard at part throttle too. i may be wrong and im starting a new thread on my tv prob.
Old Jan 5, 2009 | 12:07 AM
An out of adjusted TV Cable can make your transmission do some very strang things.
Luke
Old Jan 5, 2009 | 05:19 AM
I do understand what you are saying. Mine will shift if 9/10 of the throttle is pushed. It shifts great and no complains there. I am going to check it like I said before and she where we are at.
Maybe I will keep the tv cable a little loose and see what happens.
rstrange1996
Aug 24, 2015 10:25 PM
jrock0805
Jul 28, 2015 02:03 PM
AKDodge
May 14, 2015 12:52 PM
rabidrabbit
Mar 6, 2015 03:47 AM
Trevlar11
Nov 16, 2014 01:59 PM
