Will these lights really go in the factory location?
Old Dec 28, 2008 | 05:36 PM
dieseljunkie's Avatar
Default Will these lights really go in the factory location?
Ok, so I am looking at putting some lights on my truck.. First thing I want to do is put some GOOD factory fog lights in the factory location. Then after that I will do driving lights on a Randy Ellis Light bar, but I need to know from those that have them, will these lights on ebay bolt right into the holes in an 04 bumper? I don't currently have factory fogs, so I am looking for some that will work. I am not worried about having the factory "pull out" style switch for the headlights/foglights combo, as I have a switch in my dash that is currently not being used. I really just want to know if these lights will bolt in the factory location. I would go look myself, but there is too much snow on the ground at the moment...
eBay Motors: 02-05 DODGE RAM 1500/2500 YELLOW FOG LIGHT OEM STYLE 03 (item 360119704663 end time Jan-01-09 18:43:03 PST)
Scott
Old Dec 28, 2008 | 06:42 PM
wildbill's Avatar
Those are the ones!! Here's what all comes with the kit from the dealer:
Might be able to get the tunnels from a member here or the dealer will be able to get them.
Old Dec 29, 2008 | 10:42 AM
JTProuhet's Avatar
i found a couple OEM fog light kits on ebay for like 130 bux...
Old Dec 29, 2008 | 02:23 PM
I can get the factory fog light kits for about $130, but most of them come with the clear lenses, and I would really rather have the yellow lens for the dense fog we get around here... Anyone seen any factory kits with the yellow lenses?
Scott
Ok, my last question for now is this... Are all Rams wired for fog lights from the factory? I am noticing that some of the factory fog light kits state that the truck must be currently wired for fog lights to use their kits... But the pictures show what appear to be all the wires needed, the factory switch, and the lights... what am I missing here?
Scott
Last edited by dieseljunkie; Dec 29, 2008 at 02:23 PM. Reason: Automerged Doublepost
Old Dec 29, 2008 | 03:56 PM
wildbill's Avatar
06 and up are already wired. Meaning that all you need to do is swap out the headlight switch and install the lights and run the harness between the two lights. Look up under and behind the front end, and you should see a small square plug. If you don't see one, truck isn't prewired for fog lights.
Old Dec 30, 2008 | 01:26 PM
just went and looked, and I am pre-wired for fog lights...
Scott
Old Dec 31, 2008 | 02:28 PM
JTProuhet's Avatar
my 04.5 is also pre wired.. has a little connector right next to where the fog lights should be..
carid
Diesel Bombers Sponsors
May 7, 2015 06:40 AM
carid
Apr 15, 2015 07:29 AM
bypass-21
Jan 3, 2015 04:47 PM
