I'm assuming starter?
Old Dec 27, 2008 | 12:26 PM
Cummins97's Avatar
Default I'm assuming starter?
Truck was starting great till about a week ago and it started cranking real slow. Batteries are like 2 months old and the gauge in the dash says a little over the first normal mark. It did the slow crankin for a few days then all the sudden yesterday it started to crank slow for a few seconds then just quit crankin all together. It wouldn't crank at all for a couple turns of the key then all the sudden it would start crankin again. Now today it wont crank at all. Turn the key and there's nothin.
I'm thinkin starter what you all think? Would just check it but it's raining like a **** LoL.
Old Dec 27, 2008 | 12:37 PM
DB Admin's Avatar
Banned
tap on the starter with a hammer then try to crank it again , if there 2 pople have one tap on the starter and the other crank
Old Dec 27, 2008 | 02:11 PM
Whit's Avatar
Site Mascot
also could possibly be the starter contacts.........I think Foster makes some good heavy duty ones
here is a link to the HD contacts
LarryB's Dodge starting problems solved here.
Old Dec 27, 2008 | 02:43 PM
jasonw's Avatar
Definetly better than a starter replacement. I had the same problem in my '01. Only sometimes it would click really fast, like there wasn't enough juice to turn it over. Turns out one of the contacts was worn down so much, it wasn't making contact. I think it took an hour to pull the starter and replace the contacts. Never had a problem since. I would go that route first before changing the starter. Or if you want, pull your starter and check the condition of the contacts to make sure. I think there's instructions on how to replace them on that website. If not, I may still have mine or you can find them on the internet.
Old Dec 27, 2008 | 03:13 PM
roddyconner's Avatar
I know you said that the batteries were new, but what if you have one that's gone bad. You will show the correct voltage, but the bad one won't let you get the amps you need to turn the engine.
Old Dec 27, 2008 | 08:37 PM
94cummins12v's Avatar
ya wont hurt to start small check both batterys disconected with a volt meater, its free
Old Dec 28, 2008 | 06:38 PM
Cummins97's Avatar
Thanks for the link! You save me alot of time searchin.
Not the batteries. both tested good..
Hooked cables from another 12v to it and still same ole problem.
Looks like I'm just gonna order the HD contacts and see if that fixes it. Thx for the help guys!
Oh yea and I tried the tap on it with a hammer thing. No dice. Didn't tap to hard, scared I'd break it and be out more than the $45 for the contacts.
Old Dec 28, 2008 | 06:41 PM
stkdram55's Avatar
yeah its the contacts, i had the same problem but i didnt know about the contacts and just bought a reman
Old Dec 28, 2008 | 08:15 PM
gone ropin's Avatar
contacts, did mine about 6 years ago
Old Dec 30, 2008 | 02:00 PM
Cummins97's Avatar
took it apart and found that contacts were nice and thick still. Had alot of oil and pits on them. Cleaned them up a bit and now she starts. Still gonna order the new ones tho.
