Stuck in second at full throttle
Old Dec 26, 2008 | 06:33 PM
dangerous1965's Avatar
Default Stuck in second at full throttle
Well my truck finally is broke I think!? When I full throttle it it shifts into second and stays there?? I have to let up on the pedal to get it to shift?? Any Ideas?? I do have a BD valve body Help!!
Old Dec 26, 2008 | 06:36 PM
wildbill's Avatar
It only do it under full throttle??
Old Dec 26, 2008 | 08:25 PM
Yup If i drive normal it shifts perfect only when I'm on it or hauling a heavy load does it not shift?! Any Ideas??
Old Dec 26, 2008 | 08:28 PM
Benjamin's Avatar
Bombardier
how long has the valve body been in the truck?
Old Dec 27, 2008 | 08:33 AM
It's been in for about 6 months! about 6000 miles.
Old Dec 27, 2008 | 10:52 AM
latenite75's Avatar
Mine buddy's 03 was doing that and it was the gov. pressure solenoid
Old Dec 29, 2008 | 11:07 PM
torqctd's Avatar
Gov. pressure solenoid and sensor.
Old Jan 8, 2009 | 11:17 PM
HANGTWN_BOMBER's Avatar
The DTB As per Dodge says the main Symptoms in replacing the Governor pressure Solenoid, is "Hunting for 1st and second gear under light throttle" So im not sure if this will fix your issue... Iyt almost sounds like you might ahve a possible clutch pack issue in the transmission.
Old Feb 21, 2009 | 12:18 AM
torqctd's Avatar
Mine didn't hunt....it stayed stuck in 2nd and would not shift.
Blair@BD
BD-Power
Sep 10, 2015 12:29 PM
Jake202
Jun 21, 2015 09:42 PM
Militant83
For Sale
Mar 18, 2015 03:34 PM
Bottlerocket12v
Mar 12, 2015 09:10 PM
1stgenswap
Nov 3, 2014 09:45 PM
