Oil in water?
Old Dec 26, 2008 | 01:44 PM
Cummins97's Avatar
Default Oil in water?
A buddy of mine has a crapton of oil in the water but no water in the oil.
Head gasket?
Any other possibilities?
Old Dec 26, 2008 | 02:37 PM
ykdave's Avatar
head gasket is most likely
Old Dec 26, 2008 | 02:42 PM
94cummins12v's Avatar
yep head gasket happened to me last month spent $2800 on the problem upgrade gasket, o-ring, intake/exhaust valve springs, head studs the hole thing definatly put a dent in my day (not oil cooler)
Old Jan 20, 2009 | 02:40 AM
Cummins97's Avatar
Head gasket was correct.
Old Jan 21, 2009 | 12:46 AM
now rebuild it right so you dont have to do it again. o-ring and studs
Old Jan 21, 2009 | 02:28 AM
Cummins97's Avatar
Yes Sir!
O-ring yea, Studs, no thanks.
Old Jan 21, 2009 | 07:43 PM
why not studs? i figured since i had the head off i would do everything right, had it o-ringed, port and polished, intake and exhaust 60lb hd valve springs, oversized valves and head studs
Old Jan 21, 2009 | 10:06 PM
oglejust's Avatar
y do orings and no studs? id rather have studs and just a reg. head gasket.
Old Jan 21, 2009 | 11:51 PM
x2 unless hes worried about $$$$
Old Jan 22, 2009 | 01:04 PM
dieselfreak101's Avatar
check the tranny oil there is a tranny oil cooler under the turbo that can be prone to rust and leak. other than that keep an eye on the engine oil there might not be large enough hole and enough pressure to force the coolant into the oil.
