Fuel Plate effect on Auto trans life
Old Dec 25, 2008 | 11:24 PM
razorrodent's Avatar
Default Fuel Plate effect on Auto trans life
What is the most that can be done prior to TC and VB upgrades if any? I have a fairly low miles (75k) 2500. I tow our work trailer (~10ft box) most days and would like to get back some power. I plan on getting a Georend Heavy Hauler w billet input down the road but can't afford it atm.
Old Dec 26, 2008 | 03:11 AM
Whit's Avatar
Site Mascot
You can do a #10 or a 100 then just use yer right foot as the governor
Old Dec 26, 2008 | 09:36 AM
jasonw's Avatar
No, there is no "how much can a stock tranny take" guesses on power. Some last fine for a while, some last next to nothing at all. I'd say since you're hauling a trailer (and wanting to add power) to a stock transmission, you're asking for premature failure. Ask yourself this: you say you can't afford the tranny now, but can you afford the downtime with the truck if the tranny went tomorrow?
Me personally, I'd skip on the power until I had the transmission rebuilt.
Old Dec 26, 2008 | 10:54 AM
Thank you for the advice. That is what I had been thinking as well. I just wanted to ask to make shure. Hopefully later in the year i can cop for a built Georend or atleast the TC and VB. One of my cousins husband has owned a tranny shop for 30 years so gettign the upgrade parts installed inst an issue if i go that route rather than the Heavy Hauler.
Old Dec 27, 2008 | 08:57 PM
Hammer's Avatar
On a stock motor with no upgrades and since its a 97 automatic he would be safe with a TST 8 plate which is a 230hp/605tq and not much of a upgrade over stock.Its all Chappel recommends for a stock transmission and I would also say keep the starwheel on the tight side limiting low end fueling.Do make sure you go and do the trans though before going up any further as as they have said the stock single disc convertor will slip and then your finished until rebuild time.....Andy
Old Dec 27, 2008 | 10:47 PM
xzaq103's Avatar
FormerVendor
X2
I wouldn't go much past pushing the stock plate forward on a 180 pump that pulls a load.
Old Dec 27, 2008 | 11:11 PM
jasonw's Avatar
Who is Chappel? Does he/she/they have any experience with these trucks and "a #8 plate"? Everyone knows these transmissions leave something to be desired in stock form, let alone with any power upgrades. Couple that with constant towing and you're asking for a failure. There is no "safe limit" for a stock trans. You may get lucky with it for a while. How long? Unless you tear the transmission down and inspect each part, one guess is as good as the next.
My personal experience, my stock transmission/converter started slipping with a STOCK 215 pump and mild towing (<5000 lbs.) once in a blue moon. Food for thought.
Old Dec 27, 2008 | 11:15 PM
xzaq103's Avatar
FormerVendor
I was kinda wondering the same thing. Someone at TST???
When i was talking to Dave about my trans he was telling me about people breaking there stock inputs with stock engines just pulling 5the wheel campers. That tells ya just how bad our stock transmissions are. However they can be built up and there a lot of fun.
Old Dec 27, 2008 | 11:51 PM
jasonw's Avatar
Dave will also tell you he's seen people break STOCK input shafts at STOCK power levels with only a torque converter lockup switch, and locked 3rd to 4th gear shifts with no towing. I would believe Dave's word, too. I've personally only seen 1, but the guy was pretty hard on the whole truck.
Old Dec 27, 2008 | 11:54 PM
xzaq103's Avatar
FormerVendor
Well if you throw a lockup into the mix things can go bad in a hurry.
