Lift Pump Question
Old Dec 25, 2008 | 09:43 PM
magicman262001's Avatar
Default Lift Pump Question
Hello, not been signed up long but alot of great info. I have a 98, 24 valve, ton, ex cab, 4x4, that I just bought. Just put new tranny, clutch etc; Michelin tires, slave cylynder, and upper and lower ball joints. My question is that the truck has what I call a hick-up going down the road some times. I adjusted and reset the apps and then I got thinking the lift pump? Would this be the couse? I loosened the line going to the injector pump and bumped the key but fuel did not come out like I would have thought it would. Shouldnt fuel fly out? Next step is guage. Do you think this is my trouble????? Thanks Marvin
Old Dec 25, 2008 | 10:50 PM
Nitelord's Avatar
I'd change the fuel filter and see if that makes a difference.
Way cheaper than a lift pump too.
Welcome to DB...
Old Dec 25, 2008 | 10:52 PM
Racer9's Avatar
The most important item for those (like you) with the VP44 injection pump is a fuel pressure gauge.
Also, you are posting in the "introductions" page. Scroll down to the 24 valve section for more help.
By the way
Old Dec 25, 2008 | 10:59 PM
Diesel Decals's Avatar
Welcome to the site and Merry Christmas from Diesel Decals
Old Dec 25, 2008 | 11:33 PM
97cummins's Avatar
Welcome to DB.
Old Dec 25, 2008 | 11:45 PM
busta's Avatar
Old Dec 26, 2008 | 02:51 AM
did the filter also
Old Dec 26, 2008 | 02:52 AM
Whit's Avatar
Site Mascot
so did anything change?
Old Dec 26, 2008 | 02:56 AM
had 95 that I loved, easy to work on and everything. fuel turned up,straight pipedsounded and ran great
no not realy, filter was filthy though
when the key is bumbed to start and the pump runs for 25 sec. shouldnt that have sprayed fuel out where I cracked the lines???? If the pump was working?
Last edited by magicman262001; Dec 26, 2008 at 03:00 AM. Reason: Automerged Doublepost
Old Dec 26, 2008 | 02:58 AM
Whit's Avatar
Site Mascot
The fuel will never spray out the lines.......it will only weep at best
even with my FASS I can still only get a weep outa the cracked injector lines when I am re priming
