F-150 air bag system
Old Dec 24, 2008 | 07:39 AM
AlCorr's Avatar
Default F-150 air bag system
This is a air bag system off a 2005, F150. I believe it fits other years with same body style (2004 -2008) 2 & 4 w/d. It was on the truck for less than a year, it is complete with everything but no nuts & bolts. Air Lift Ride Control Kit & Air Lift Controller II w/ Dual Gauge. Cost over $570. w/frt and asking for $200 plus fright. If you don't want the air bags, (they don't fit your ride) the air pump system alone is worth the money.
Google; "Air Lift #59544"
Old Dec 29, 2008 | 04:50 AM
AlCorr's Avatar
$150 plus fright.
Old Jan 5, 2009 | 05:45 AM
AlCorr's Avatar
Old Jan 5, 2009 | 05:11 PM
Benjamin's Avatar
Bombardier
i wander if i could make this fit a 99 f-250.....
what is the total height of the bag from bracket to bracket?
Old Jan 6, 2009 | 04:20 PM
AlCorr's Avatar
The "L" bracket on top goes under the frame and bolts to the side of frame, (in pre-drilled holes) The bottom set's on the leaf spring. The distance between the bottom of frame and top of spring is about 6 1/2 inches. The air bags look tall but they set beside the frame, not under it. Hopes this helps.
Old Jan 20, 2009 | 04:57 AM
AlCorr's Avatar
YES, They are still available.
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
