Stacking Quadzilla Xzillarider 2 w/ Rokk
Old Dec 24, 2008 | 05:53 AM
AlCorr's Avatar
Default Stacking Quadzilla Xzillarider 2 w/ Rokk
Is anyone else stacking Quadzilla Xzillarider 2 tow with Rokk Timing Sender, besides me. I have downloaded the max mileage setting on the Quad and I have the Rokk timing sender advanced all the way and don't get any rattling from my engine. I use this set-up all the time towing a 10,000lb 5er. Will I hurt anything doing this?
I've called Quadzilla customer support and asked, how mush does this mod advance the timing. All I got was 7 degrees on every setting, I find this hard to believe, but they are NOT going to give away any of their secrets.
Old Jan 18, 2009 | 11:09 AM
wildbill's Avatar
Too much timing is hard on the engine, so keep an eye on your gauges.
Old Feb 6, 2009 | 02:13 AM
SOUTHERN GA SMOKE's Avatar
not only is too much timing hard on the engine, it will also melt cylinders, keep and eye on your egt's remember with advanced timing egts cool down, so if your running a hard stack, and your egts to seen to be matching up to what they should, you either have an extremely good turbo/s or running way too much timing...
Old Feb 6, 2009 | 05:55 AM
GRI's Avatar
GRI
I have been running the rokk tech with my x2 standard and xzt boxes. I asked the question over on DTR and the timing on the rokk tech is like .5 degrees or something like that.
I plan on removing my rokk tech when I get my bully dog, as some guys said they were getting timing rattle. I'll have that up for sale if interested.
and just an FYI. dont waste your time with the M3 tune. You'll get better fuel mileage out of the 65hp setting
Old Feb 11, 2009 | 01:03 PM
AlCorr's Avatar
Not sure if I understand , my egt's never get too high, unless I'm pulling a long grade towing.
Baradium
5.9L 24V Performance
Dec 14, 2014 05:04 PM
MAC4232
Oct 16, 2014 04:22 PM
